Brakes lock when first start driving.
Old Oct 1, 2005 | 12:46 AM
WD92TA's Avatar
From: Pensacola NAS, Florida: Hometown Valparaiso, Indiana
Car: 1992 Trans Am
Engine: 305 TBI
Hi, I have a 92 Trans Am with a 305 TBI. Its brakes worked fine when I first got it, but it had been sitting awhile. But now if I let it sit for a couple of hours and go to drive it the first couple of times I hit the brakes they are very sensitive and squeek really loud but after hitting it a couple of times it is better. It also feels like the car pulses to a stop from high speed but not hard braking. My idle also seems to search, could it be vacume leak? Please help it is embarrasing in the school parking lot when your brakes are squeeking!
Old Oct 1, 2005 | 01:00 AM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
for starters... since the car has been sitting for a while, replace the rubber brake lines. Brake fliud will decay the inner hose and cause your calipers to stay applied after you remove your foot from the brake
Old Oct 1, 2005 | 12:54 PM
Speedy Mike's Avatar
Car: 92 Firebird Conv
Transmission: T-56 w/3.42 Posi
yea, I have the same problem, I have TBI and it seems as if the idle is increases and decreases. Anyone know why??
Old Feb 14, 2006 | 08:23 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Just wanted to bump this thread up as Im having the exact same problem, and it has nothing to do with the idle.
Old Feb 15, 2006 | 05:07 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
BRAKEY BUT SHAKY
Originally posted by WD92TA
...................It also feels like the car pulses to a stop from high speed but not hard braking.................Please help it is embarrasing in the school parking lot when your brakes are squeeking!
<CENTER><B>Your rotor(s) are warped, replace them.<P>
‘Bout the squeak, coat the metal side of your brake pads
with anti-squeak compound.</B>
<P>
<TABLE BORDER=9 CELLPADDING=18
<TD BGCOLOR=black WIDTH=60><B><H3><CENTER>REFUSE
.TO
.LOSE</TABLE></CENTER>
Old Feb 15, 2006 | 11:34 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Anyone know about the sensitivity? I like it and im wondering if there is a way to always have it, maybe slightly less.
Old Feb 16, 2006 | 12:25 PM
WD92TA's Avatar
Car: 1992 Trans Am
Engine: 305 TBI
Well, I found out that it was my rear brakes and they are drums so they aren't warped. But I took it in to a shop and they found that the shoes were only working when I first begin to drive and then they don't work so they cleaned and adjusted them and they worked at first but now they don't. I think I need to bleed the lines. Any other ideas would be great. And thanks for the comments and ideas already.
Old Feb 16, 2006 | 01:24 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I think only my fronts work when I first start up, and all the pressure is applied to them. Ive heard the ebrake is supposed to adjust the rears? Well if its been sitting for a while, the ebrake will travel a lot farther at first, and then it tightens up. So im wondering if something on the rears is backing out. I seem to remember hearing something about this and its a typical problem. Today I will pump my ebrake first and then ill see if my brakes do the same thing.
Old Feb 17, 2006 | 06:41 PM
NINÅ's Avatar
Transmission: 765R4
Well, I found out that it was my rear brakes and they are drums so they aren't warped............took it in to a shop..............
<CENTER>
<B>Pulsating brakes are caused by warped rotors or drums. You
can test for it yourself by rotating the wheels by hand with the car
off the ground, while your pads are lightly touching.<P>'Bout the
sensitivity, check for rear axle grease getting on your linings. Let
the car sit overnight. In the morning do not drive it.........pull your
rear wheels off and inspect for axle grease. (It leaks past your axle
bearings) Squeaking on your rear brakes is consistent with
contaminated brake linings, so check for that grease.
</B>
<P>
.TO
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
