drum to disc conversion
Old Oct 13, 2005 | 08:33 PM
CamaroSS_Black's Avatar
Car: 1986 Z28
Engine: L98 Block Vortec Heads Comp Xtreme
Transmission: Built 700R4
Axle/Gears: 10 bolt with Auburn 3.73 posi unit
ok i just bought a 9 bolt with discs out of an iroc and i have an 86 z28 i dont care about the speedo but i need to know what i need to mount them up
thanks i appreciate all the help i can get
Old Oct 13, 2005 | 09:07 PM
TA_drag's Avatar
Car: 85 Trans Am
Transmission: t5
Did you get the calipers ,brackets and brake lines with the rear? you will need different ebrake cables and I am not sure if the proportioning valve is the same from disc to drum.
Old Oct 14, 2005 | 09:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You'll find all the info you need.
JamesC
Old Oct 19, 2005 | 10:50 PM
Ragtop89's Avatar
I'd like to see what others have to say as well.
I'll be doing a drum-to-disc swap on a 9-bolt soon and I'm doing as research as I can.
Linson
Oct 24, 2025 02:00 PM
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
