C5 rear disk conversion Q's
Old Oct 24, 2005 | 09:25 PM
carzar252's Avatar
Car: 88 camaro
Transmission: 5 spd
Axle/Gears: 10 bolt, 2.23
ok guys this might be a stupid question but I have to ask. I am doing the entire C5 big brake upgrade from www.bigbrakeupgrade.com. I am seeing on there that you can get C5 rear calipers too.... I am woundering if this is a compatible component with the "Ls1 rear disk upgrade" or even the "Lt1 rear disk upgrade. I know what i need for the "drum to disk" upgrade but i wanted to know if the C5 caliper works with these set ups
thanks
Old Oct 24, 2005 | 10:49 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
C5 rear calipers = LS1 rear calipers.. Get the Z06 rears if you want them red..
Kevin D.
Old Oct 25, 2005 | 10:31 PM
carzar252's Avatar
Car: 88 camaro
Transmission: 5 spd
thanks man... thats all i wanted to know.. and by the way, has any one had a chance to get some results with the stoping performance with the C5 kit? i know its bigger and better but I just wanted to hear some testimony
Old Oct 26, 2005 | 09:59 AM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
I don't have any actual numbers, I can say that the difference between the stock brakes and C5 fronts was amazing. I also switched to LT1 rear from the stock drum brakes around the same time. Basically the stock brakes wouldn't even lock up the larger 17/18" wheel/tire combo I was running, after the C5 brake swap it left skid marks on the first test drive. One of the best mods I've done so far to the car.
hectre13
Dec 11, 2023 08:14 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Warlocksirix
Sep 3, 2015 12:26 PM
lt1z350
Aug 28, 2015 05:57 AM
stalkier
Aug 13, 2015 12:59 PM
