earls EAR-28A190
Old Nov 10, 2005 | 07:09 AM
TRANSAM38387's Avatar
Car: 1987 GTA
earls EAR-28A190
i'm doing a 1le swap all the way around and was wondering if the earls EAR-28A190 brake line kit came with 4 or 5 lines. from what i understand a stock 1le car had 5 rubber lines, 2 up front, 1 from the body to the rear end, and 2 from the rear end to the calipers. is this right or i'm i mistakin. any help would be great
Old Nov 10, 2005 | 11:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
They'll fit. Check the following link:
https://www.thirdgen.org/techbb2/sho...hreadid=249098
JamesC
Old Nov 10, 2005 | 11:15 AM
That is correct.
The 1LE cars were no different in that respect from the other 89-up cars with rear discs.
Although, you may find that the fitting on the end of the lines, has "corners" that interfere with the caliper casting. You could either grind the corners, or use 2 copper washers.
Old Nov 10, 2005 | 11:21 AM
JamesC's Avatar
I've read that that problem occurs; however, the lines fit my car without modification.
JamesC
Old Nov 10, 2005 | 01:13 PM
Right, seems like some calipers they fit, and some they don't. I have no idea why they're different.
Old Nov 10, 2005 | 05:37 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Let me clear some things up for you. Yes, the 28A190 kit has 5 lines, 2 front and 3 rear.
Now, as for this:
"Although, you may find that the fitting on the end of the lines, has "corners" that interfere with the caliper casting. You could either grind the corners, or use 2 copper washers."
This will not be an issue with 1LE calipers. This only happens when people try to install 1LE lines on stock calipers which have a small circular area where the banjo goes onto the caiper, the 1LEs won't have this problem and you won't have to grind anything.
Ed
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
88305tpiT/A
Aftermarket Product Review
Oct 1, 2001 10:13 AM
Apeiron
Jul 4, 2001 10:15 AM
