baer rear brake kit
Old Nov 12, 2005 | 01:55 AM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
baer rear brake kit
hey guys,
i'm looking to ditch my crappy stock rear calipers/parking brake mechanism due to the obvious reasons. i have my heart set on a baer system, specifically the sport system with the 12 inch rotors so they can fit my 16" GTA cross-lace rims. my question to you guys is: who sells the sport kit? i've seen the touring kit all over the place, but that won't fit because of the 13" rotor. anyone know anyplaces where i can get my hands on a sport kit?
-Mark
Old Nov 12, 2005 | 04:15 PM
GTAman's Avatar
also, can anyone tell me how the installation goes? that'd be great.
Old Nov 14, 2005 | 02:53 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I have done this swap already but I purchased the pieces individually and put it on at a later time. I would say the hardest part is getting the axles out of the housing. The rest was a breeze provided that I hadnt broken 2 hard lines, damn rust. Where in NJ are you? I am in the Trenton area.
Old Nov 14, 2005 | 02:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If your have your heart set, then the following may not be of help, but it is an alternative (and probably cheaper):
https://www.thirdgen.org/techbb2/sho...hreadid=249098
JamesC
Old Nov 14, 2005 | 07:33 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Like James stated, the Baer rear Sports are no different than an '89-97 rear brake setup so you may just want to go that route. I can put one together for you in no time if you'd like.
Install is as described above...Pull axles, change backing plates, reinstall axles, and install all the brake stuff. Shouldn't take 2-3 hours to do.
Ed
Old Dec 11, 2005 | 04:50 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Rear Discs 87 Iroc
Hi,
Sorry to jump in, but contemplating similar addition for my 87 Iroc
showcar. Have been running the 13" Baer Claw front discs with
thier aluminum hubs for a few years with my 16" Iroc wheels.
Yes they clear! Don't like thier price on comparible rears so was
thinking of going to the newer 12'' 3rd gen rears. Are thier any
problems with the E-brake setup on them. from what I got from
Baer thier is a problem on thiers Costwise-ballpark?
Am running the 9 Bolt BW.
Later
Irocing
Old Dec 11, 2005 | 07:49 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
look into 98-02 swap too. superior parking brake
Old Dec 12, 2005 | 02:22 PM
jaykar's Avatar
Rear Discs 9-Bolt
Hi,
Thanks will do. Just trying to find bigger rears without alot
of hassels with the E-Brake and maybe parts can pick up
salvage and work with
Later
Irocing
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
red90IROCls1
Aug 25, 2015 06:56 AM
kyleb24
Aug 15, 2015 08:24 AM
