lack of brake power help
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey guys havent posted up in a while since i bought my 98 ss maro.but well my 89 rs has stock disc/drum setup .i replace the shoes in the rear and the pads in the front and bleed the whole system by hand. pedal doest go as far down as it use to but there is still not full brake power.also untill my car doesnt reach normal working temp it wont brake good,why is it that when its cold the brakes baerly work?wat should i do next?how do u know if ur prop vavle or master cyl are bad?
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
Ive got lots of problems too but maybe this will help http://www.classicperform.com/TechBo...oubleshoot.htm
