Do I need to have an ebrake??
Old Nov 20, 2005 | 09:19 AM
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
I have a rear out of a 90 z28. It has the 12" discs and pbr calipers. Well when swapping i noticed the cables won't work. So can I remove the cables and all of the parts that hold the cable and the brakes and will still work and adjust properly??
THanks,
Mark
Old Nov 20, 2005 | 10:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A is always a good idea. The part number that you need is in the following link:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
Old Nov 20, 2005 | 04:29 PM
maroguy1's Avatar
Ok thanks but I read it and that post also says that the cables are discontinued. All I really want to know here is: does the e brake adjust these calipers at all??
Old Nov 20, 2005 | 04:41 PM
JamesC's Avatar
I provide the CarQuest part number for the cables in the link (the OEM are discontinued). The e-brake does not adjust PBR's.
JamesC
Zepher
Brakes
111
Jan 4, 2025 10:38 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
MasterEvilAce
Aug 29, 2010 02:01 PM
theSteve
Aug 21, 2003 04:37 PM
TekViper
Mar 27, 2003 07:36 PM
