lines for line lock Q (lost instructions)
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Hey
I lost the damn instructions. And I know it is not a hard thing to do, but how do you run the brake lines when installing line lock? Thanks
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
If trying to lock the front brakes, take the line off the rear of the master cylinder into the TOP port (at leasy on my Hurst) of the LL. THen route one of the 3 bottom ports into the proportional valve where the master cylinder line used to go to. The other 2 ports can be plugged and not used (or add a gauge and bleeder there if you want (but no need to).
mdtoren
Aug 16, 2015 05:45 PM
