master cylinder
Old Nov 30, 2005 | 05:37 AM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
master cylinder
looking at changing the master cylinder and was wondering if anyone has done this.
I would like to go to a chrome one like this from summit
SUM-760100 this is a 1 inch bore
would this work I have no idea what the bore is on our rides...help
Old Nov 30, 2005 | 03:12 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
As far as stock Thirdgens go, GM used a 1" main bore MC on the cars with the Delco-Morraine rear discs, while PBR and rear drum cars got a slightly smaller 0.944" MC.
However, the Thirdgen MC is also a "fast fill" design, with a larger secondary piston, that reduces the amount of pedal travel required for take-up.
That Summit MC is probably not a fast fill type. So, you can expect that it will require a longer pedal stroke, to bring the pistons into contact with the caliper. After that take up phase is complete, pedal effort will either be the same, if you already had a 1" GM MC, or it will be somewhat higher in comparison to what you have now if you already have a .944" MC.
Personally, I like the shorter pedal stroke of the fast fill MCs, so I wouldn't switch. But that's personal preference more than anything else. As long as the new MC has adequate stroke available (and it probably does), it'll just be a difference in feel more than anything else.
HTH,
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
