LS1 front brakes offset causing wheel rub
Old Dec 11, 2005 | 06:42 PM
89camaroRSV6's Avatar
I did a search about this and was not able to find anything that would be useful, so I decided to ask
Its an 89 camaro RS with ROH snyper rims. I upgraded my front brakes to LS1 brakes. I have 17X9 rim in the front with 245/45/17 tire in the front. The problem is I am not using the stock steering stop (I couldnt find any way of keeping the stop, when I upgraded). I have not extended the stops that are on the A-Arm.
The problem now is when I go lock to lock left or right it rubs. On the right handed turn the inside of the tire hits the inner fender wall, and while going in it hits the fender plastic cover underneath a little bit on the back side ( I will try to post pictures tommorow). On the left handed turn it doesnt hit the fender wall on the inside at all from what I can see, but it still hits the inner plastic cover a little.
I noticed that the tires have come out like .3 of an inch. Is there any remedy / solution to this problem?.
Another question on the same topic. If I upgrade my rears to LS1 brakes as well. I run a 17X9.5 275/40/17 tire in the back. Would the offset come out or go in. Going in would be bad as I have like an inch maybe less between the inner tire and the wall on the back.
Any thoughts?.
Old Dec 11, 2005 | 06:54 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Any thoughts?.
First question: No, this is just the way it is and how this setup is installed, you must lose the steering stop for the necessary bracket clearance. I guess if you bought another wheel with .250" more backspacing you'd be fine. Are you running spacers on the front wheels?
Second question: No change in rear offset, rotor hats and drums will give you the same spacing so all is well back there.
Ed
Old Dec 11, 2005 | 06:59 PM
Ed
Thanks ed!
I am not running any spacers. The Snypers I got were made for correct offsets for front and back for the 3rd gen's. Is there anything else I can do like extend the stock stops on the A-Arm?. I dont think the plastic rubbing the tire on the fender cover on the bottom is as big as a problem as the inside of the tire rubbing the fender wall, unless someone tells me otherwise.
Glad to know about the rears...those were really begining to worry me.
Old Dec 11, 2005 | 09:37 PM
ebmiller88's Avatar
Rubbing the plastic liners will give you no problems, you can always get another set of those..I have a few just in case I ever need them. Maybe you should modify the A-arm stops if you keep having troubles, that's my only suggestion...and make wider turns when you can.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
