ever since..
Car: 1991 Z28
Engine: SBC
ever since..
Ever since i started driving the car with the new motor, the brakes have sucked. The peddle is hard as a rock to push down on..usually requiring two feet to stop short. Like the car feels like it has the ability to stop fine..but the peddle is so hard to push. I think it may be my brake booster but im not sure. I drove today and when i popped the hood, brake fluid had come outta the booster and gotten all over the wires and unit itself. any thoughts?
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
sounds like the brake booster. Check to make sure you properly connected the vacuum hose on the brake booster after installing the new engine. If you have a large cam you may not be pulling enough vacuum at idle and low speeds.
Do you mean the master cylinder reservoir? If fluid is coming out at the brake booster that means you have a bad seal on your master cylinder and your master cylinder and brake booster will have to be replaced.
Car: 1991 Z28
Engine: SBC
crap haha im an idiot...the vac line on the intake side was unplugged...brakes work fine now..minus the ebrake...but ill figure that out later
Glad you got it fixed, and easily at that. Brake problems suck.
Car: 1991 Z28
Engine: SBC
what a relief...this resto was killing me. The car needs paint and some body work = $$$...then tires = around 450$..and then brakes? i was like ahhh ****. Glad it was just that
Anoying Eric
Jan 15, 2011 10:21 PM
