dual brake lines going to rear?
Old Dec 24, 2005 | 03:12 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
Are there third gens with 2 brake lines running to the rear. my 91 RS only has one. and if not can i just order 2 pre-bent lines that i will just mount next to one another to make it dual lines to the rear?
Old Dec 24, 2005 | 11:42 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
why would you want them and how would you route them? there are only 3 ports coming off the prop valve.
Old Dec 25, 2005 | 12:23 AM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
ill be using a 4th gen rear and a 4th gen prob valve. and i would route them just like the stock lines only there will be 2 right next to each other
Old Dec 25, 2005 | 12:39 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Why?? Just used the lines on the rear for a 4'th gen without ABS. Then use the stock thirdgen line going to the rear.
From my understanding the only 4'th gen's that have two lines going to the rear are ABS which means there is no proportioning valve, the lines go to the ABS unit.
Old Dec 25, 2005 | 02:01 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Im using the entire 4th gen braking system from the master cylinder to the ABS module or whatever the brake lines come out of. So i need the 2 lines so i can run them to the 2 lines on the rear.
Old Dec 25, 2005 | 03:37 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
First off, how will you be setting up ABS on your car? Where are you mounting the sensors on the front wheels?
Old Dec 25, 2005 | 03:55 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Actually only my rear tires will have ABS the fronts wont.
Old Dec 25, 2005 | 04:09 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Um you better do some more research on this. You can't just tie some lines to a ABS unit and think it will all work out. If you somehow got the thing to correctly operate without all the added body control module and stuff the 4'th gen has, ABS only on the rear is completely useless. Your fronts are going to lock before your rear.
Old Dec 25, 2005 | 05:03 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
well im using the entire 4th gen harness and sensors, added with all the braking controls and units from the 4th gen. Isnt there an ABS sensor in the rear that controls the rear ABS unit. and maybe i will disable the ABS but im still using the 4th gen distribution box for the brake lines and will still need 4 brake lines
Old Dec 25, 2005 | 05:47 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Why?
If you're deciding now that you don't want to setup the ABS, then why use the ABS pump/box dual lines and all that crap?
Spend the money you're thinking about spending on this one larger brakes. You'll be happier.
Old Dec 25, 2005 | 05:52 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Maybe you need to explain better what complete setup you are trying to do. Engine, brakes, etc. If you are going to run a 4'th gen harness are you going to run a lt1 or LS1. Right not it just seems likes you are making some over complicated monstrosity. Don't bother with the ABS it is a waste of time and money and really makes absolutely no sense at all if you are just using it for the rear.
Old Dec 25, 2005 | 06:05 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Im using an entire setup from a 2000 LS1, including harness, engine, and components. I have the 4th gen brake cylinder, and the 4th gen brake distribution box, it needs 4 lines going to it(1 line from each wheel). so im trying to get 2 lines going to the rear the easiest way.
Old Dec 25, 2005 | 07:03 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
just a posibility, i think these cars use the same rotors as light trucks, and some of them had abs, im not sure where the reluctor ring is located, but maybe look into it
Old Dec 25, 2005 | 07:15 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Okay, it makes a lot more sense now what you are doing. If you are not going to run ABS up front don't bother with it. It would greatly simplify the install not to use ABS at all. The 4'th gen's have the wheel speed sensors for the front wheels built into the hubs mounted on the 4'th gen spindle. To use ABS on a thirdgen a wheel speed sensor would have to be somehow rigged up for the front. Since you are using a 4'th gen rear it would already have all the ABS sensors on the rear. To save yourself a enormous headache just don't run ABS.
Old Dec 26, 2005 | 01:23 AM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Ok i wont run ABS but i will still need 4 lines, 2 going to the rear correct? even tho im not running the ABS the 4th gen brake distribution thing needs to have lines from the 4 wheels.
Old Dec 26, 2005 | 03:24 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
If you're not running ABS then just run directly out the Master cylinder, 2 ports for the front--one for the rear and put an adjustable prop valve on the rear line that goes to the Y block on the rear axle.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
