What size/fitting is the rear drivers side brake line on the EAR-28A190 kit?
Old Jan 9, 2006 | 10:37 AM
Dr G's Avatar
I currently have Earls Stainless Steel Brake Lines on my 1989 GTA. Part number EAR-28A190. I need to replace my rear drivers side line with something a few inches longer, as it is currently a little too close to part of my exhaust system for my liking.
Does anyone know what size/fitting is the rear drivers side brake line on the EAR-28A190 kit? I would like to phone up a company and just have them send me a line with the correct fittings to the length I specify.
Otherwise, should I simply remove this line and buy a longer piece of stainless steel hose (?6 mm or 1/4" which is ~6.35 mm)? Can this be joined to the existing fittings?
Old Jan 9, 2006 | 12:14 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
This should work for you, then just get a -3AN line and a -3AN 10 mm banjo fitting to finish it out. Also read through this thread as it has a little more fitting info, the part numbers are listed by KagA152:
https://www.thirdgen.org/techbb2/sho...hlight=fitting
Frame fitting, tubing 10 mm x 1.00 bubble flare to -3 male
220-6890
Ed
Attached Thumbnails What size/fitting is the rear drivers side brake line on the EAR-28A190 kit?-220-6413.jpg
Old Jan 9, 2006 | 03:31 PM
Dr G's Avatar
Many thanks Ed!
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
timonator
Aug 11, 2015 09:56 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
