Caliper Confusion
Old Feb 1, 2006 | 11:03 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Caliper Confusion
I'm shopping around for aluminum calipers and i've noticed there only seem to be 2 types. One cast iron single-piston (which I already have) and the 2 piston aluminum (occasionally labeled "performance package) The 2 piston is the 1LE replacement right? I want 4-wheel aluminum calipers (as close to PBR as I can get) so my question is will the 2-piston calipers fit on my J65 setup? I'm not looking to be a 1LE-wannabe, I just want lighter, BETTER brakes.
Also......anyone have anything AGAINST the Cardone brand of calipers/pads, etc?
Thanks..
Eric
Old Feb 1, 2006 | 11:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are you talking about the front or the rear?
Old Feb 2, 2006 | 06:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Two-piston fronts (1LE) will require spindle modification. Single-piston PBR rears require a new backing plate. Here's the how-to:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
