C5 brake upgrade complete!
Old Apr 25, 2006 | 04:13 PM
Camaroz29's Avatar
Man, what a huge difference and worth every dollar. Pics can be seen here:
C5 brake upgrade complete - CamaroZ28.Com Message Board
Old Apr 25, 2006 | 06:57 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
Did you have to use washers to space out the abutments bracets from the spindle bracket? My spindle brackets from Ed make the abutments rub on the rotor. I am going to have to use some washers to move them over a bit.
Old Apr 25, 2006 | 07:56 PM
Camaroz29's Avatar
Mine don't do that. I went to bigbrakeupgrade.com, the kit came fully assembled and bolted right on.
Old Apr 29, 2006 | 09:37 PM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
Lookin' GOOD ! Nice job
Old Apr 29, 2006 | 11:33 PM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
My kit from Ed came with washers to make them fit perfectly. You should send him a PM and see what you need to make it right.
Old Apr 30, 2006 | 08:11 AM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Transmission: TH-350
Axle/Gears: Open...
So the kit for the front is a no brainer on where to get and what to do, but what about a C5 kit for the rear of a 4th gen rearend? I go the rearend for no spacers on ZO6 wheels.
Old Apr 30, 2006 | 01:53 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
I am doing the c5 rear brake swap. So far I have the ls1 rear backing plate parking brake assembly, lt1 axles, ls1 rotors, c5 calipers and abutments. I have been reading that there really isn't much to it. The reason I am using the ls1 parking brake is because it is a much simpler swap. Check out this site for a little more info:
PhantomSS.Com - Jason Debler's Home Page
Old Apr 30, 2006 | 04:15 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Ready to spoil your party...C5 calipers/carriers won't bolt onto LS1 backing plates. I have the parts in the shop and I'll post pics of both later.
Sorry!
Ed
Old Apr 30, 2006 | 04:16 PM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Axle/Gears: Open...
So a rear LS1 swap - LS1 calipers/brackets + C5 Calipers/brackets?
Old Apr 30, 2006 | 08:17 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Ed, I just found that out. The C5 abutment bolt holes are bigger than the LS1 and with the Power Slot LS1 rotors that I am using I am off 1/4". Oh so close. I am going to try to make a bracket that moves the abutment down a little bit. I think I can make it work. I will keep you posted. I can't fully make a bracket yet as the axles are in because the rear is put together yet because I can't find a case spreader...but I am working on it.
Old May 6, 2006 | 08:58 AM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Transmission: 5-speed
Do they sell a full bolt-in kit, or did you have to do some fab work?
Old May 6, 2006 | 09:02 AM
Camaroz29's Avatar
It is a direct bolt in.
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
KO1
Aug 31, 2015 06:31 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
