Metal Brake Line Size?
Old Apr 26, 2006 | 02:38 PM
Shake Zula's Avatar
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
I need to replace the metal line that runs from the MC to the front right rubber brake hose. What size is it? and 60" should be long enough right? Cuz thats the biggest autozone sells.
Old Apr 26, 2006 | 04:33 PM
Shake Zula's Avatar
I got 60" of 1/4". Looks like its not enough and too big. So mabey its 3/16?
All they have is hard line, it dosent seem too flexible. Id almost rather patch the tiny hole with JB Weld than try bending all that metal line.
Old Apr 28, 2006 | 11:43 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
I just replaced the metal lines on the rear of my 86. If you have a cheapo tubing bender it isn't all that hard. Yes the lines are all 3/16" by the way.
Old May 1, 2006 | 10:41 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
should be able to bend it by hand, if it's got that wire wrapped around it. 3/16" with inverted flare fittings are on my car, apparently later cars had metric bubble stuff on it.... dunno about that.
Reddeath210
Oct 6, 2015 08:20 AM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
