Rear Disk center (t hose)?
Old May 4, 2006 | 10:32 AM
JB22's Avatar
OK guys, im re doing my rear brakes and im missing something. The rear is out of a 91Z with PBR brakes.
I have new steel lines (2 pieces) and the rubber hoses that goes to the caliper.
I need the piece that goes between the 2 steel lines and the primary line from the master cylinder. It has like a brass fitting with a rober hose.
Whats this thing called? Napa couldnt find it listed under disk brakes, but they found one under drums. Is it pretty much the same thing? They called it a center hose.
Any feedback is appreciated
Old May 4, 2006 | 09:14 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
I dont know about year to year, but on the F-body CD, for a 91, its showin the same part for both drum and disck rears. The GM# its listing is 17980325, HOSE, Rr Brk M/Cyl (to axle).
Actually, upon further inspection, its showin that same hose for all rear ends from 88-91. So if they can cross reference that GM number with theirs, your golden.
Old May 5, 2006 | 04:25 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
last time i looked it was called the center brake hose.
Old May 5, 2006 | 07:19 AM
JB22's Avatar
awesome!
Thanks for the info man.
Old May 6, 2006 | 06:26 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I have a few of those braided center hoses if you'd like to go that way, it'll be better than a stock rubber hose...LMK if you'd like one, $30 shipped to you. It's an Earl's hose, BTW..
https://www.thirdgen.org/forums/part...light=earl%27s
Thanks!
Ed
Old May 6, 2006 | 08:48 PM
JB22's Avatar
Already picked up a OER version. Put things back together today.
Thanks for posting though
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
