Police car brakes!!!
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
Hey Guys,
I have a friend with a 89 caprice police car. Will the brakes off the car work on my 90 IROC???? If so what all do I need to swap to make them work.
Thanks Mark
Thanks Mark
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Your probably confusing the popular B-body swap for G-bodies. The caprice, cop car spindles fit right on G-bodies with a shortened upper control arm, this gave you bigger 12" rotors and bigger calipers and rotors. It also gave you a much better camber curve although bump steer gets pretty bad.......any way the rotors and calipers only work on B-body spindles so no it won't work on your 3rd gen.
Terrell351
06-13-2021 01:13 PM
