parking brake adjustment
Old Jul 16, 2006 | 10:05 PM
mgrd's Avatar
I'm having a problem finding the parking brake adjustment bolt/whatever on the underbody, I was wondering if anyone had a picture of the underbody showing whereabouts. I have an 1986 v6 camaro.
Thanks guys,
Matt
Old Jul 16, 2006 | 11:18 PM
MJH91RS's Avatar
Car: 91Camaro RS
Engine: 305TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Are you just talking about tightening it or loosening it? The adjustment i used was in the console attached to the actual emergency brake arm. There are slots there where you can make the cable tighter or looser. There might be one under the car, but I am unaware of that one.
Old Jul 17, 2006 | 05:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Under the car above the drive shaft. A is always a good idea.
JamesC
Old Jan 16, 2007 | 12:34 PM
xbcrguy182x's Avatar
does that mean you have to drop the driveshaft to adjust it?
Old Jan 16, 2007 | 12:59 PM
JamesC's Avatar
Dropping the drive shaft makes the process MUCH easier.
JamesC
Old Jan 16, 2007 | 01:07 PM
Ah interesting...is it easy to drop the drive shaft?
Old Jan 16, 2007 | 01:20 PM
JamesC's Avatar
Yes. Four small bolts at the rear of the shaft, pry or yank the U-joint out of the pinion yoke without loosing the caps, pull the shaft rearward so that it comes out of the trans. You'll lose a bit of fluid. Personally, I'd scribe the shaft/pinion yoke so that the shaft went back in exactly as it was (avoiding possible vibration issues.).
JamesC
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
