Calibers Rusted Shut
Old Aug 24, 2006 | 02:56 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
Im new with working on cars and my front caliber is rusted like crazy. I unbolted it but i can figure out why it wont come of. Im not sure if its rusted on or that theres some other bolt that i missed. If anyone knows or has an idea what is wrong please help.
Old Aug 24, 2006 | 03:05 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
First, it's caliPer.
Second, did you press the brake pad in? You need to open the bleeder valve and force the brake pads into the caliper. Then take it off.
Old Aug 24, 2006 | 03:06 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
The caliper has two bolts which I assume you removed. The brake pad is probably too tight against the rotor. Take a BIG c-clamp, one end against the outer pad and the other against the back side of the caliper, and try to push the piston back into its bore. It won't take more than a little movement to free up.
Old Aug 24, 2006 | 03:28 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Ok. Which valve is the bleeder valve? The bolt on the top of the back of the caliper or the bottom? Or is it another one? Those are the only other two I saw.
Old Aug 24, 2006 | 03:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The one on the top opposite where the brake hose attaches. It looks more like a little fitting, usually with a rubber cap protecting it.
Old Aug 24, 2006 | 04:23 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Its off. Thanks.
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
tcflint
Sep 27, 2015 05:58 PM
ironbmt
Sep 27, 2015 06:00 AM
