Custom wheel size
Old Sep 5, 2006 | 06:37 PM
Tranny's Avatar
Car: 87 Trans Am
Engine: 434 being built
Axle/Gears: 3:73
Custom wheel size
American racing wheel's custom shop can change the dimension's on this wheel (offset,backside, bolt circles). What I need is what sizes will allow me to upgrade brakes later. I would like some wide tires in the back & something in the front that is about as wide as my 245x45x16's. Can anyone help?
Last edited by Tranny; Sep 5, 2006 at 06:57 PM. Reason: site american racing wheel & offset templates
Old Sep 6, 2006 | 07:11 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
What wheel? No link or pic. What brakes are you considering?
Ed
Old Sep 6, 2006 | 07:31 PM
Tranny's Avatar
Car: 87 Trans Am
Axle/Gears: 3:73
I thought I placed a links but I guess it did not work. It was at the American Racing Wheel home site and it was called "Trakstar S" with a custom offsets.
Old Sep 6, 2006 | 09:10 PM
ebmiller88's Avatar
OK, stock front backspacing is 4.5". Let's say you install a set of C5 brakes which will add .300" or so to your front track width...have the wheels made with .300" or so more backspacing and you're all set, like 4.75" BS to match the rears and you can then rotate them any time you want without having to change tires.
Ed
Old Sep 7, 2006 | 07:17 AM
Tranny's Avatar
Car: 87 Trans Am
Axle/Gears: 3:73
Great Idea. I'll check to see if they could make a template for that size.
Old Dec 8, 2006 | 02:59 PM
BOTTLEDZ28's Avatar
Transmission: A4
I am looking foe the same info. I want to get 17x9.5 TT2 wheels with a 5.75" backspacing for the front and and maybe either 5.5 or 5.25 for the rear. Im hoping that will work for the front when I put the C5 brakes on. Does this sound like a workable option here Ed? If the 5.75" backspacing in the front hits the tierod then maybe I will add a smaller spacer until I get the C5 brakes put on. I just want a deeper lip on my rear wheels.
toronto formula
Nov 10, 2015 06:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
kah992
Aug 19, 2015 02:55 PM
knight72
Aug 10, 2015 09:32 PM
