Brake Drum won't go on...
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
I just installed new brake shoes and now the drum won't go on over the new shoes, i think i really need to have the drums turned, the inside edge has a little corrosion but i'm sure the drums should slide on over the shoes without too much difficulty.
Yes the parking brake is off and the self adjuster is all the way in..
This is the drivers side - havent attempted the other side yet.
Engine: 350 HSR
Axle/Gears: 3.43
OK, i had the drums turned and they still dont seem to fit right.. can anyone tell if i even have the shoes on the correct way round? one of the shoes has a longer section of material on it and i wantedd to make sure i have the shoes on in the correct order.. It just seems as though something is out of round, surely the drums must be good and round now since i just had them turned?
Any advice anyone?
Any advice anyone?
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Turn the adjuster at he bottom of the brakes so the the shoes come in toward the center and you should be able to fit the drum back on. The adjustment has rotated out as the old shoes wore down and now must be readjusted so the Thicker/newer shoes have room.
I hope you can follow me. I'm better at doing than explaining.
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
Ricco: How did you get that drum on? Im in same situation except my pass side fits on perfect. I have the shorter shoe toward the front and the longer shoe toward the rear. Adjuster is bottomed out. THe Driver side drum wont even reach the wheel studs? It makes it 1/3 way on shoes.
New shoes and drums by the way. And i have nudged the shoes around and uninstall and installed them like 4 times.
