brake line q's.
Old Oct 8, 2006 | 09:37 PM
SmallTires's Avatar
Car: 1984 Camaro Z28
Engine: Roller 350
Axle/Gears: built ten bolt 3.73's
brake line q's.
I have been searching and am kinda in a spot for the info I need. Basically my car is an 84 camaro, however a later rear has been swapped in. It is a disc, ten bolt setup. I really want to get a set of ss brake lines for the car as my stock rubbers are about to go. However my problem is that apparently when I go to buy a set there seems to be something slightly different about them as 84 seems to be its own year in terms of parts. What this is I have no clue, but I figure I would ask. This couple with a rear that is newer makes the package seem impossible. So basically will the later ten bolt use the 84 rear disc lines and be ok? Or do I just need to buy a later model kit, unless they revised the front brakes as I currently have teh stock 10.5 up front.
Old Oct 9, 2006 | 05:54 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
http://www.spohn.net/product.cfm?productid=1426
JamesC
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
