How yo properly seat new disc brakes?
Old Oct 9, 2006 | 07:37 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Transmission: Built 700r4
Axle/Gears: 3.73's w/ stock axles
Just like I said, how do you do it properly and safely?
Old Oct 9, 2006 | 09:40 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
if your talking about breaking the new pads in after replacement.
i do around 8~10 light stops from around 30~40 MPH, letting the brakes cool down for about 2~3 minutes between each stop. i then let them cool for around 10 minutes & do 4 or 5 medium stops from around 60 MPH, again, letting them cool down about 5 minutes between each stop. for most pads this is enough to get them seated in for normal driving.
Old Oct 9, 2006 | 09:49 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Thanks dude. Thats exactly what I was looking for. This is the first time I do my own brakes (and it was from stock 10.5 fronts and drum rear to 1LE's all around) and I just wanted to make sure that I wasn't driving around dangerously!
Old Oct 10, 2006 | 05:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've read about seating brakes, and IIRC, I even messed around with it when I went 1LE, but interestingly enough when a shop has done my wife's brakes (Chrysler LHS and Jeep Cherokee), no mention of seating has ever come up. So how important is it to a normal consumer?
JamesC
Old Oct 10, 2006 | 06:27 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
It probably isn't very important, but it doesn't hurt and just may make me feel better if nothing else. So I figured why not.
Thanks guys
Old Oct 11, 2006 | 03:07 AM
DENN_SHAH's Avatar
JamesC, they should have done a test drive after the brake job before they let you have the car.
during the test drive is when we seat the brakes, we seldom tell our customers that we seat them in, just that we did a test drive after we finished the job. i would never turn a car over to the customer with out taking a test drive, i have to know the car stops like it should.
i have used pads that claim they don't need to be broken in, they seem to work better right out of the box but they also seem to squeal more later on.
Old Oct 11, 2006 | 05:31 AM
JamesC's Avatar
Does your test drive include all the steps in the seating process, or is it simply a short drive to determine that all's generallly good with the system?
JamesC
Old Oct 11, 2006 | 12:45 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
For procedures on pad bedding, rotor seasoning, and bleeding, look on Baer's site:
Baer Brake Systems
Click on Baer Tech, then click on Braking 202-How-To guides, this should cover it for you.
Ed
Old Oct 11, 2006 | 08:53 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Thanks again, ed. I knew I had read that procedure somewhere, I just forgot where. Thats the procedure that I did (almost) and with these things, I can slam my wife into the windsheild at will!! (Like I would eaven think abiut it )
Old Oct 11, 2006 | 10:51 PM
DENN_SHAH's Avatar
JamesC, it depends on the customer.
some of our customers never get over 20 MPH, a few of them will be running 80+ as soon as they hit the freeway.
at minimum we do 8~10 light stops with 1 or 2 medium stops. that will give the average driver dependable stopping, long brake life with a minimum of squealing problems along with rotors that will stay true for the life of the pads.
they are all told the brakes are not fully broken in, & not to use them hard if possible for around 200 miles, if we put on new rotors, around 400 miles.
this covers 99% of all drivers, its that 1% that needs more, but you know who they are, they want the best parts & don't care what the price is.
Old Oct 12, 2006 | 05:32 AM
JamesC's Avatar
Cool. Thanks for the reply.
JamesC
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
overdriv
Aug 20, 2015 03:52 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
