IROC disc rear into 91 rs camaro
Old Nov 27, 2006 | 05:18 PM
m6_hurst_z28's Avatar
Car: 99 Z28
Engine: LS1 w/ cam, bolt ons.
Transmission: M6
Axle/Gears: 3.42 torsen lim. slip
I'm looking for information on swapping a disc brake rear end from a 1986 IROC into a 91 camaro rs. I need info on the proportioning valve, parking brake setup,etc.. I would appreciate any info or a link to some info.
Old Nov 27, 2006 | 07:17 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Waste of time & effort installing those POS rear brakes. Better options out there.
Old Nov 27, 2006 | 08:30 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
What's the gear ratio in the Iroc rearend?
Old Nov 27, 2006 | 10:31 PM
Car: 99 Z28
Transmission: M6
The IROC rear is a 3.23 POSI. I wanted to put the rearend into my 91 rs convertible because i have a complete 86 IROC donor car with a damaged body.The RS has a 2.73 rear w/drums.
Old Nov 28, 2006 | 05:25 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
With the recall kit installed (if it isn't already), the rear discs on the 86 will work fine--and will provide a better ratio and limited slip. The disc rear would also allow easier upgrades, as DJP suggests, such as the following:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Nov 28, 2006 | 05:33 AM
ebmiller88's Avatar
I wouldn't waste your time on the old calipers and just upgrade to PBRs right off the bat, you won't be sorry.
Ed
Old Nov 28, 2006 | 09:44 AM
Car: 99 Z28
Transmission: M6
I know that there are better options out there, but I have a 86 IROC w/complete rolling chassis for a donor. I want to replce the 2.73/drum rearend in my 91 RS with the 3.23/disc rearend out of the IROC.Basically what i'm asking is what other parts do i need off of the IROC to make my brake system work correctly with the IROC rearend installed on the 91 RS.
Old Nov 28, 2006 | 10:35 AM
JamesC's Avatar
Originally Posted by m6_hurst_z28
i'm asking is what parts i need off of the IROC to make my brake system work correctly with the IROC rearend installed on the 91 RS.
We didn't do much to answer your question, did we? Check the following link for master cylinder info:
https://www.thirdgen.org/forums/susp...fferences.html
Because I'm ****, I'd replace the M/C and proportioning (combo) valve. The emergency brake cables will be different. Maybe someone else will chip in here, as IIRC, the emergency brake attachment in the tunnel is somehow different. Also, if you plan, at some point, on upgrading, keep the pieces you remove from the 91.
JamesC
Old Nov 28, 2006 | 04:30 PM
ebmiller88's Avatar
As James stated, now we get it. You'll need the whole rear, the e-brake cables, and the master and prop...and I strongly suggest at least rebuilding the rear calipers or you'll see no drastic improvement. You may have an issue with the e-brake cables as your '91's adjuster is different than the one on the '86. Good luck!
Ed
Steven 86IROC-Z
May 24, 2026 04:52 AM
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
mustangman65_79
Aug 11, 2015 03:17 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
