My 89 Formula and my 70
Engine: 4++,350 & 305 CIs
89 front brakes
http://www.team3rdgen.com/modules.ph...view_photo.php
89 rear brakes
and the 70s fronts under construction...
had to sneak this in
hope its ok
http://www.team3rdgen.com/modules.ph...bum.php&page=8
89 rear brakes
hope its okhttp://www.team3rdgen.com/modules.ph...bum.php&page=8
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I hear ya, Tony, very nice work. I'm particularly fond of the work on your '70.
What brackets did you use for the rear..Baer?
Ed
Ed
I havent mounted calipers to the rear of the 70 yet.. but I have them. Im using another set of fronts on the rear
they are the same price as 4 piston rears so why not use a 6
I think I can use a 98-02 caliper mount and a Baer plus 1 bracket for 98-02 rear brakes.. car will be mini tubbed with a 335 30 18 tire in the rear
the E-brake will be from a Ford GT 400 bucks a side
the cables are 80 apiece then pads, then, then, I'll be in the poor house
I should have been clearer in my post. In this link below, which bracket is that?
Are they used with the black adapters also pictured? Reason I ask is that I'm working on a 13" rear brake kit using the LT1/1LE PBR calipers and a two piece rotor. I'm just curious as to what "kit" that is.
Ed
Ed
The old looking bracket is off of my cars original 9bolt. I redrilled it (and removed the dust shield) for the Ford 9" rear ..
The gold bracket along with the black adapter is from Baer. it works with the 9" Ford rear
Linson
Oct 1, 2015 09:50 PM
