need help on flare size.
Old Dec 29, 2006 | 06:14 PM
n36ryder05's Avatar
I have a 88 camaro with rear brake drums. Im having trouble figuring out the flare size on the line that goes to the rear and hooks up to the center brake hose. And the flare that from the rear brake line that hooks up to the splitter in under the hood. Whatever size it is advanced auto parts and auto zone says thay dont carry flares that big. Napa might have it but they dont know exactly what size it is.does anyone know?
Old Dec 29, 2006 | 06:18 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
it should be 1/4od double flare, i assume you are looking for the threaded fittings that go on the tubing? i was looking for the same things and could not find them so i had to reuse the old ones, try a auto salvage for a used piece
on and the front lines are 3/16?
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
If you dont have the old evuipment you can search the salvage yard, i have a few of those laying arround but no clue as to what size.
Old Dec 29, 2006 | 07:19 PM
n36ryder05's Avatar
ok thanks
Old Dec 29, 2006 | 07:20 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
It will be a metric treaded fitting but should be a 1/4" or so line, I can't recall the thread size off the top of my head.
Ed
Old Dec 29, 2006 | 10:47 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
what you need is european threads on 4 or 5 mm (i dont remember what size exactly) double flare line
fyi, most junk yards wont sell you brake line because of liability issues
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
billybob6110
Feb 11, 2016 10:41 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
romcjr
Sep 17, 2015 05:18 PM
RED85TPI
Brakes
Aug 31, 2015 10:29 AM
