Not being able to stop = no fun.
Old Jan 19, 2007 | 02:13 AM
Red92Bird's Avatar
Car: '92 firebird
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 10 bolt 3.42 gears with eaton posi
So, the other day as i was leaving school i looked down to mess w/ my radio for a split second, as i was finding the right station , some kid thought it would be funny stuff to stop at the green light and hold everyone up till it turned yellow. i looked up and slammed on the brakes as hard as i could, only to find that they didnt even have enough power to lock the front wheels . luckily i stopped about 6 inches from the back bumper of his rusty pos toyota pickup. almost sh@t my pants. So whats the deal here anyone have ideas? my brakes work great when stopping normally but in a hard stop you swear that a gremlin stuck an invisable block of wood under the brake pedal. i couldnt lock up the front tires even if i wanted to. i have a 92 firebird with drums in the rear.
Old Jan 19, 2007 | 06:56 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
unfortunatly thats normal for these cars.. lightly press on the pedal with one toe or stand on the pedal with both feet doesn't make much of a difference.
Old Jan 19, 2007 | 08:01 AM
B Rhodes's Avatar
Car: 91 B4C
I have to disagree. I have a 87 ta and 91 camaro L98 and both will lock the fronts with med/high pedal effort. Sometimes cheap pads or pads that have been hardened from over heating do this. But if you have good pads and rotors it should lock with out too much trouble.
Old Jan 19, 2007 | 08:27 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
ANOTHER "PICK-UP TRUCK IS JEALOUS OF A CAMARO STORY""
You didn’t say but it sounds like you were
going only 10 to 20 MPH.
At that speed you should be able to stop quick enuff
to send your school books thru the windshield.
You can have a number of issues that can cause your problem:
wrong pad compound, restricted brake lines, old calipers, etc.
If you don’t know the age of the calipers and flex lines replace them.
Make sure that someone didn’t put race compound pads on,
they don’t grip enuff till they are hot.
Happy Racing !
— If people drove any slower
they’d be going backwards —
Old Jan 19, 2007 | 01:35 PM
Red92Bird's Avatar
Car: '92 firebird
Engine: 305 tbi
thanks for the input, im thinking the pads might have something to do with it. they must be cheap, because from high speeds you can usually make one good stop but you get bad brake fade after that. the car will barely hold itself at a stop light when the brakes are really hot. when running it hard the pads have overheated and started smoking a few times. weve had the car since new and it has all origional brake parts except pads and maybe rotors. and to NINA, i was going about 35 mph. there is a two lane entrance road to my school with a stop light at the end.
Old Jan 24, 2007 | 03:11 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I recommend purchasing a parachute.....just in case................. lol
Old Jan 24, 2007 | 04:06 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i think you need to replace a few things as well.. brake flex hoses, fluid, pads, etc.. go for steel braided lines and get quality pads as well.. replace ALL the fluid and bleed the crap outta it.. that should fix your problem.. you might have had air in your lines as well.. good stop, then heats up and expands fluid out of lines, starts to fade, then gets hotter and pushes more fluid out of the lines..
Old Jan 25, 2007 | 05:18 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
ummm, locking up the brakes is BAD for stopping.
Old Feb 6, 2007 | 11:31 PM
Red92Bird's Avatar
Car: '92 firebird
Engine: 305 tbi
I know it takes longer to stop with the tires locked up, but they dont even get near locking. my point is that no matter how hard you push on the pedal, they wont lock. As far as i know, any car with normally functioning brakes and no ABS should be able skid the front tires if u push hard enough.
Old Feb 7, 2007 | 04:40 PM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
Old Feb 7, 2007 | 08:42 PM
Car: 89 formula 350
Ive never been able to lock my brakes....hopefully can next week after the ls1 brakes go on.
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
