Hydroboost
Old Feb 25, 2007 | 05:51 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Hydroboost
Anyone installed a Hydroboost system? Results?
Old Feb 25, 2007 | 07:11 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I've run hydroboost on other cars and trucks... I like it!
Use the one for a 1983 Cadillac Seville with a 5.7 diesel. This car is built on the "X" platform like the Nova from the 70's and the bolt holes are pretty close... You can get a matched master cylinder set up for 4 wheel disc as a factory option as well...
Old Feb 26, 2007 | 07:52 AM
Wadebryant's Avatar
Interesting. Use the 83 Cad described for 3rd gen cars?
Old Feb 26, 2007 | 09:04 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Yep!
The diesel Seville ran from 77 to 85; the reason that I chose 83 is because I had one (for parts) and it had the nice 4 wheel disc setup and an aluminum newer style master cylinder with the Plastic top (similar to the ones on our cars now.) I think you will be happy with the setup. I'll be installing it on my car as well as soon as I get some more garage space. I just moved to Florida and am in a transition apartment until I buy a house...
Old Feb 28, 2007 | 09:02 AM
chesterfield's Avatar
Car: Pontiac
Not positive but that should be a Hydroboost II. No external accumulator. They stopped making them and went back to the original design, Hydroboost I.
You're not going to find anything that's a direct bolt-in.
Old Mar 1, 2007 | 03:26 PM
wanta427's Avatar
Car: 1991 Z-28
Engine: 350 L98 al head Stealth Ram
Axle/Gears: 3.42 LS1 brakes
http://www.hydratechbraking.com/
Old Mar 1, 2007 | 04:33 PM
Car: Pontiac
Originally Posted by wanta427
Which one would you buy?
Old Mar 1, 2007 | 05:36 PM
wanta427's Avatar
Car: 1991 Z-28
http://www.hydratechbraking.com/foru...opic.php?t=107
Old Mar 1, 2007 | 07:57 PM
Car: Pontiac
I stand corrected. That's about $300 for a bracket and some hoses.
500+hpta
Brakes
83
Sep 10, 2023 05:24 PM
anesthes
Aug 24, 2015 08:18 PM
direngrey
Brakes
May 20, 2013 04:46 PM
supr_fly03
Brakes
Jan 31, 2013 09:18 PM
87350IROC
Brakes
May 26, 2009 06:48 PM
