How to upgrade a 9-bolt to 1LE brakes?
Old Mar 11, 2007 | 12:26 PM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
Hi all ! I took the white IROC out of storage today. The brakes were rusty so I drove around to clean them off. I accidently was doing some burnouts (8 or 10 of them) and I discovered that my rear discs are not working at all. Good for burnouts but bad for panic stops. I have the stock '88 rear disc setup and I am not going to spend the money to fix it (again) !!! What do I need to put the 1LE upgrade to it? Just go buy some Calps and rotors for an '89 up F-body or is there more to it?
Thanks in advance, Mike
Old Mar 11, 2007 | 03:55 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
You also need the 89 specific backing plates. Ed Miller is the man you want to talk to. I am sure he will chime in and help.
Old Mar 11, 2007 | 08:50 PM
Sound good, What about E-brake cables? Brake lines? How much do these backing plates go for? ED ! Are you there?-Mike
Old Mar 11, 2007 | 09:41 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
You will use the parking brake cables for an 89 disk brake car. When I worked at NAPA they could get them. That was two years ago.
Old Mar 12, 2007 | 05:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Everything you need to know:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Mar 13, 2007 | 12:34 AM
Thanks James, That is a great thread. I have some more questions though. How much should I be paying for this stuff? What should I be sorcing from the junkyard? I went to Advanced with some of those numbers and they looked at me like I had 3 heads!
Also are the rear brakes off of an LS-1 car compatable?
-Mike
Old Mar 13, 2007 | 05:28 AM
JamesC's Avatar
Originally Posted by mike graycar
How much should I be paying for this stuff? What should I be sorcing from the junkyard? Also are the rear brakes off of an LS-1 car compatable?
I doubt you'll be able to find much at the bone yards, though taking a peek certainly wouldn't hurt. You also might consider the classifieds on this site for both calipers and backing plates which would no doubt save you some money. Everything you require, however, is available new. You might do a search on the LS1 stuff. I know that's an option these days.
JamesC
Old Mar 15, 2007 | 05:34 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I have everything you need..brake lines, cables, backing plates bolt on for a 9 bolt. Please send me an e-mail, I'll take care of you.
Ed
Old Mar 16, 2007 | 08:39 AM
Well, I think I got some rear 1LE's and maybe fronts too. Stick around as I'll probably need some help along the way. Thanks James and ED.
James, I have been stuying that link. Do I indeed need a drum brake master cylinder? that seems strange. I'd bet there are alot of guys running around with the old disc brake MC who don't know this.
Old Mar 16, 2007 | 08:43 AM
JamesC's Avatar
I run the drum brake master, but....
https://www.thirdgen.org/forums/susp...fferences.html
JamesC
Old Mar 16, 2007 | 10:18 AM
So, I can run either/or, Interesting!
James, Thanks for all the help and the speedy reply. Do you have a job or do you just hang around on the brake board? LOL !
Old Mar 16, 2007 | 10:21 AM
JamesC's Avatar
Retired. I'm probably the oldest fart on this site!
JamesC
Old Mar 16, 2007 | 10:38 AM
JamesC
I here that, I'm getting up there myself! Home from work today due to the snowstorm. Watching "Magnum P.I." and remembering what it was like to be young!-Mike
Old Mar 18, 2007 | 07:01 PM
All right, I purchased a used setup here on the classifieds for a fair price. It has the rotors, calps, backing plates, soft lines and cables. Before I start taking it apart. Do I use the stock hard lines that are there or will I need to replace those?
-Mike
Old Mar 18, 2007 | 08:42 PM
JamesC's Avatar
The stock lines from your 88 won't fit. Check my link for manufacturer and part number for the correct lines.
JamesC
Old Mar 18, 2007 | 09:08 PM
I saw that, I think it says one side works and the other side needs to be replaced. Now that I am thinking about it I have a donor rear and I'll bet that out there in the yard, Covered with snow I have the brackets I need. Of course I am a genius so I cut the housing up with a sawzall to make it fit in the trunk of the Honda. So I am sure I cut the lines also. Oh well, I should be putting new lines on there anyway.
How important are the brackets for the E-brake cables? I have the T/A Performance rear cover and I'm not sure they will fit with the recessed mounting holes.
James, Nice car !!!!
Old Mar 19, 2007 | 05:29 AM
JamesC's Avatar
How important are the brackets for the E-brake cables? I have the T/A Performance rear cover and I'm not sure they will fit with the recessed mounting holes. James, Nice car !
If you don't feel like crawling around in the snow, AndyZ28 fabs the brackets:
http://www.andyz28.com/3rdGen/reardisc.html
The e-brake guides keep the cable away from the exhaust, so I'd do something. Here's another choice (from ebmiller):
https://www.thirdgen.org/forums/atta...brake-4c57.jpg
Thanks for the compliment about my ride.
JamesC
Old Mar 26, 2007 | 12:04 AM
Re: How to upgrade a 9-bolt to 1LE brakes? PROBLEMS!
Well, I started the upgrade today. Where do I put the brackets that hold the hard line/soft line connections? I printed out the pics from James's thread to use as a reference but I lowered my car and used the Sphone relocation brackets to restore the proper angle for the lower control arms. Anyone done this before? Any solve-all solution?
-Mike
Old Apr 17, 2007 | 05:18 PM
AAARRRGGGHHHH!!!!!! Well, we're not done yet. I finally got the car out for a test drive. First, bleed brakes. What's this? Very little fluid coming out of rear bleeders. Swap out MC for a new one, Drum brake one by the way. Now it bleeds the way it should. Test drive: Little to no activity in the rear. Cannot lock up rear wheels. Does spectacular burnouts as the rear brakes are still not working. What have I done?
Old Apr 18, 2007 | 12:46 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
How do you know the rears aren't working? They should never lockup, or at least not before the fronts do. As far as I know none of the factory prop valves will send enough pressure to the rears to lock them them up.
Try jacking the rear of the car in the air and put into drive. Once the rears are in the air tap the brakes and see if they stop rotating. The J65(?) brakes are notorious for doing nothing.
Old Apr 19, 2007 | 08:58 AM
Well, when I bleed them they were grabbing. Couldn't turn the rotor with a pry bar. The calipers moved freely. Now, as for the brake testing. I did it in a sand filled parking lot. Got up to 40 and stood on the brakes. Bad pedal and the rears did NOTHING ! Also on high speed stops the car takes forever to slow down and you can smell the fronts burning. The J65 brakes, That is the old set-up I had before?
Old Apr 19, 2007 | 10:32 AM
trumps2000's Avatar
Car: 1985 Z28
What makes you think the rears are doing nothing? You said they grabbed when you bled them.
Remember 60% or more of the braking is done by the fronts, maybe they need some servicing? What is bad about the pedal? Is it soft, does it go to the floor?
The J65 is the older setup. I still use them, I just bypassed the factory prop valve with an adjustable one to get them to work properly.
Old Apr 21, 2007 | 05:31 PM
Well, The pedal is soft and does almost go to the floor. The backs don't seem to be doing anything at all. In gravel at 20 MPH I can lock the fronts but the rears don't disturb the driveway at all.-Mike
Old Apr 21, 2007 | 05:47 PM
JamesC's Avatar
IIRC, the J65 option included 89-92 PBR's. At any rate, did you use shims to center the caliper over the rotor?
JamesC
Old Apr 21, 2007 | 05:54 PM
JamesC's Avatar
Originally Posted by trumps2000
Remember 60% or more of the braking is done by the fronts.
I've read as much as 70%.
JamesC
Old Apr 22, 2007 | 10:37 AM
Hummmnnn...... Shims you say? No, As I understood the ten bolt rear may nees to be shimmed. The nine bolt uses offset backing plates. Marked L and R. I put one on to mock up the brakes when I first started and if you are using the wrong side you see it. The rotors look to be perfectly centered within the calipers and pads.-Mike
Old Apr 23, 2007 | 05:26 AM
JamesC's Avatar
IIRC, the 10-bolt is marked in the same manner. I had my head tucked away there for a moment. From everything I've read the 9-bolt didn't require shims.
JamesC
Old Apr 24, 2007 | 10:45 PM
MilehighBird's Avatar
Car: 1987 Firebird Formula
Engine: 305 LG4
Sorry that you are having problems with your brake swap. You didn't mention if you bench bled the new master cylinder before you swapped it. If you didn't you'll have air trapped in there no matter how many times you bleed the lines.
Old Apr 26, 2007 | 12:27 AM
Hey there!
Yes, I did bench bleed it. It was a PITA, The front wouldn't bleed right. I swapped out the new drum brake MC for an old disc MC I know is good. Now I have a good pedal. THANKS ADVANCED A-P !!!!! The rears are working but wount lock up even if I stand on it with both feet. Tommorow I will start the front upgrade and go from there.
Old Apr 27, 2007 | 01:02 PM
I think I have it figured out. The backs are working but the fronts are glazed from being overheated. I have a few questions about doing the fronts.
1. When I cut and drill the front spindels for the 1LE brakes, Do I go all the way through with the holes?
2. What do I do with the proportioning valve? There is some question about the threads on the early VS. late models. What is up with that. Can I use the prop. valve from a '92 on my '88?
3. Where do I get rebuild kits for the PBR calipers?
Thanks-Mike
Old Apr 27, 2007 | 02:17 PM
JamesC's Avatar
1. No.
2. The following thread may provide the info you need:
http://web.archive.org/web/200605221....html#1LEfront
3. Any auto parts store you be able to furnish a rebuild kit.
JamesC
Old Jun 6, 2007 | 07:49 PM
Here's a new thought. My rears still aren't working up to snuff. Do I need E-brake cables on there? I remember seeing something about having to set the E-brake to make the rears adjust themselves properly
Old Jan 4, 2008 | 08:03 AM
strc09's Avatar
Car: 1988 Pontiac Firebird Trans AM GTA
Engine: Tune-port Injected 6.3L
Transmission: Borg-Warner T56 six-speed
Axle/Gears: Borg/Warner 9-bolt with 3.70:1
Bringing this one back from the dead...
What is the difference between the 1LE brake calipers and the standard WS6 brake calipers on the GTAs? Also, can just the calipers be swapped out or do you have to change everything for it to work? Thanks.
Old Jan 4, 2008 | 08:13 AM
JamesC's Avatar
The so-called 1LE disc rears (89-92) have 11.7" rotors and single-piston alum calipers. Pre-89 have 10.5" rotors and single piston Delco-Moraine iron calipers. No direct swap. However....
JamesC
Old Jan 4, 2008 | 08:26 AM
strc09's Avatar
So it comes down that I can't just buy 1LE calipers and put them on in place of the stockers that I have. I had heard some where that they have a two piston stock caliper for our cars and I thought it was the 1LE caliper. Guess not...bummer.
Old Jan 4, 2008 | 08:29 AM
JamesC's Avatar
Correct. The front 1LE's are two piston, but, of course, they won't fit without modification either.
JamesC
Old Jan 4, 2008 | 08:30 AM
ebmiller88's Avatar
Two piston front 1LE caliper, yes..but not the rear. Most rear disc parts are now discontinued but I have a nice sized stash in the shop, LMK if you need any.
Ed
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
