Brake pressure?
Old Apr 4, 2007 | 11:42 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Brake pressure?
Hey if you have new rotors fresh brake pads and brake fluid looks full. What could be wrong that the brakes feel soft? like takes a good while to slow down not too long but definately screwed in and emergency situation.
any ideas?
Old Apr 4, 2007 | 11:53 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: Brake pressure?
did you bleed your brakes when you were done. that would be the first thing i would try. hope this helps
Old Apr 5, 2007 | 12:29 AM
Bobby_80s's Avatar
Axle/Gears: no idea
Re: Brake pressure?
I reset the caliper piston what do you mean by bleed? I think I knwo what you mean but I cant think of it at the moment.
Old Apr 5, 2007 | 03:45 AM
Re: Brake pressure?
here is one link that talks about brake bleeding. if you have a haynes manual it also says how to.
http://www.stylinconcepts.com/Articl...g/article.aspx
basically what you are trying to do is get the air out of the brake line, air compresses much more than the brake fluid, that is why the pedal feels soft or spongy
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
g.l.mos
Aug 22, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
