Brake Backing Plate on 9 bolt
Old Apr 10, 2007 | 04:45 PM
bimmerjohnny's Avatar
Hey everyone. I need to replace my backing plate on my 9 bolt rear end can not seem to find the correct plate. Mine has 4 bolts attaching it all others have 2. Also anyone have any ideas on how to take it off and install a new one????? I was tring to remove the wheel cylinder and the back plate rusted through and put a huge hole in the back plate. Anyway thanks for everyones help in advance. I really need to get this thing going.
Old Apr 10, 2007 | 05:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Brake Backing Plate on 9 bolt
Have you got discs or drums?
Old Apr 10, 2007 | 06:20 PM
Drums.
Old Apr 10, 2007 | 08:41 PM
Anyone???? I know I can go buy new back plates but how do you get the old ones off and what kind are they I only see the 2 bolt ones. I have repair manuals but they dont make it clear on how to get the back plate off. Thanks for any help.
Old Apr 12, 2007 | 11:25 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I pretty sure you have to take the axle out of the rearend, and also take the brake cylinder off.
Old Apr 13, 2007 | 03:13 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You will have to remove the wheel cylinder and the two lower bolts, then the plate will come off. The wheel cylinder will be the hard part.
Ed
Old Apr 16, 2007 | 07:52 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Ed
Ed, I thought you had to take the axle out?
Old Apr 16, 2007 | 08:04 AM
How Hard is it to take the Axles out, and there are 4 bolts not just 2??
Old Apr 17, 2007 | 11:36 PM
ebmiller88's Avatar
Yes you do, I was describing the backing plate removal on a drum rear.
Ed
Old Apr 18, 2007 | 10:07 AM
net_coma's Avatar
Axle is not difficult to remove and reinstall but it is a pain in the azz. Just be sure you have room on both sides to slide the axel out. I can't recall if the 9-bolt has the pin retainer but if it does go get a battery post tool to remove that bolt/pin. It is better than anything I have used.
1992 Trans Am
May 10, 2023 07:19 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
