Front end pulls all over when applying brakes....
Old May 9, 2007 | 12:43 PM
25thannivZ28's Avatar
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
Okay, so here's the scoop...
Originally when I hit the brakes, it pulled hard right. I called Summit to order new SSBC front brakes and got them right away. I pulled the old rotors off, re-packed the bearings, put them into the new rotors with brand new races. Had to replace the driver side caliper, cuz it was froze. THOUGHT that would have solved the problem. Well I get it together & it pulled hard left now. I figured cuz the original factory calipers were only $10.00 + $15.00 core, i'd pick up the passenger side caliper & replace right away. When all got put together, I tried to bleed it and realized I am not getting any brake fluid to the passenger caliper! WTF??? I proceeded to replace that brake line & got plenty of fluid, bled both sides & now i'm ready to rock. Well, thats what I thought. I took it out and now it is pulling hard left, pulling hard right & overall getting out of control when I hit the brakes hard. I have to counter-steer just to brake in a straight line. So the whole front end is brand new, brake line, calipers, rotors, bearings packed, pads & plenty of fluid. Whats next, any ideas? suspension??
Last edited by 25thannivZ28; May 9, 2007 at 12:50 PM. Reason: Added "So the whole front end...."
Old May 9, 2007 | 12:49 PM
Axle/Gears: 4.10:1
Re: Front end pulls all over when applying brakes....
I think I may have my answer, I found another discussion on here saying it maybe a bad brake line. It was only the passenger side brake line that was replaced. Because the other side worked just fine with pressure, it doesn't necessarily mean that its still AS GOOD as the brand new one. I'll try that and re-post.
Old May 9, 2007 | 12:55 PM
DerrickB4C's Avatar
Car: 1991 CAMARO RS
Engine: 305TPI SOON TO BE 350 TPI
Transmission: 5 SPEED
Axle/Gears: STOCK FOR NOW
my 91 dose the same thing it looks like a rear line is busted for me. i have fluid run down on the thq arm and on the floor pan around the rear of the drive shaft tunnel. at first i thought it was the rear end seal but the rear end wasnt wet. i have to track that line down my self.
Old May 9, 2007 | 04:16 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
If it is in the front if it where me I would pm Ed and order up a set of steel hoses.JMOP
Old May 11, 2007 | 06:03 AM
Axle/Gears: 4.10:1
Yup, replaced the driver side hose last night, it stops like it never has before!! Lesson learned is buy this in pairs, i never knew that!
Old May 11, 2007 | 07:00 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I've posted about this subject about once every two years: Stock rubber brake lines are good for only seven to ten years if the brake fluid isn't changed on a periodic basis. My car's lines failed at year number seven, fourteen, and at age sixteen I put in braided stainless lines, and began changing the fluid every 24 months. The brake fluid picks up water and this causes the inside of the rubber lines to break down.
Old May 23, 2007 | 09:07 AM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
Yup, Stock lines suck. This is one of those rare times when the problem is easy and cheap to fix. Hey 25th, How do you like that ZZ-409 cam? I was thinking of getting one for my stealth-rammed 383.-Mike
Old May 23, 2007 | 10:02 AM
Axle/Gears: 4.10:1
Yah, I LOVE the ZZ-409 cam. Night and day difference between the comp cams cam that I had before w/a .480 lift. It (the ZZ-409) pulled hard up to 6300 w/my twin runners from my TPI, but now that i upgraded to Mini-ram, its pullin easy to 6600 before I manually shift it to prevent blowing up my motor. Good Choice!! I'm takin er down to GLD on Friday to see the results.
Old May 23, 2007 | 09:10 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Please read:
https://www.thirdgen.org/forums/faq-...ulls-side.html
Ed
Old May 24, 2007 | 06:15 AM
Axle/Gears: 4.10:1
Originally Posted by ebmiller88
Thanks, I appreciate the lead....I had fixed it already though.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
bellez77
Sep 5, 2015 08:39 PM
sreZ28
Aug 14, 2015 07:48 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
