HELP! Parking brake in rearend swap
Car: '86 Trans Amvanian Frankenbird
Engine: 350 4bbl
Transmission: T5 4.03/.76
I'm currently trying to swap rear axle assemblies between two Firebirds, but I'm unsure as to how best to disconnect the parking brake cable. Should it be disconnected from the wheel or from the lever? I would like to avoid removing the entire cable if possible, but that sounds more appealing than getting into the brake drums. Any input on this would be greatly appreciated.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: HELP! Parking brake in rearend swap
if you want to take them off the handle side, there are retainers that snap into brackets in the drive shaft tunnel, get them unsnapped there and then you should be able to unhook them from the puller assembly.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I purchased a tool, but I've heard that you can snug a zip tie around the tines tightly enough to slip the cable free.
JamesC
JamesC
Yupp! When i swaped the borg warner i got outa an 86 back into a different 86 this is how i did it, very easy. Took me an hour on the ground.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
