Earls s/s lines won't seal!
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
new ls1 front calipers new banjo bolts earls brake lines and both sides seep out fluid it seems to becoming from between the caliper and the brake line what else can i try?
Re: Earls s/s lines won't seal!
On SOME calipers, but not all, the place where the fitting goes has a round counterbore; but the Earl's fitting is a big square thing. If you have the round place, the corners of the fitting will hit the casting and won't crush the washer.
Try either grinding the corners off the fitting; or using 2 washers between the fitting and the caliper (plus the one between the banjo bolt and the fitting).
Car: 92 camaro RS
Engine: LSA
im using aluminum washers thats what came with earls lines im going to see if anyone has any around here but i will go check on the clearances first
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Are your calipers powder coated? Check to see if some of the coating got in and around the bolt hole, this will prevent the washers from sealing. Ran into this problem with a set of rear PBRs on my brothers '94 bird. Dremel and a sanding roll and all was well.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Make sure your banjo bolt and brake line fitting are both 10mm, any play here could cause a leak.
Ed
Ed
Car: 92 camaro RS
Engine: LSA
well ordered two more calipers both of them weren't machined even where the brake line bolted down.
ambainb
Apr 25, 2016 09:21 PM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
