C5/C6 brake wheel offset?
Old Sep 10, 2007 | 08:40 AM
cavazos31's Avatar
Car: 1988 camaro sports coupe
Engine: Fast Burn 385
Axle/Gears: 9 bolt w/ 3.27 gears
I've read that swapping a C5 or C6 brake kit would require the use of spacers, and I'm wondering what size spacer is required. What size spacers are you guys using? Does the size of the spacer required change with the type of rims or offset? I have 18" boyd timeless (18 x 8 in front) and a C5 brake upgrade that I haven't installed yet. The backspacing on the rims is 4.75 inches. I would like to avoid using a spacer if I could, so I'm interested in what size spacer is required so I can possibly get front rims with the proper offset. Any help on the subject would be greatly appreciated. Thanks.
Old Sep 10, 2007 | 04:14 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: C5/C6 brake wheel offset?
you dont need a spacer just the right size rim diameter, the rotor acts like a spacer pushing the wheel 1/4" out
Old Sep 10, 2007 | 07:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the issue is wheel diameter and how the wheel is shaped. Some wheels have the "spokes" shooting inward towards as they get farther out from the center of the rim, and this causes clearance issues with the calipers, there is a fitment sheet diagram on BigBrakeUpgrades website, its good for reference.
Old Sep 10, 2007 | 07:45 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Most often with stock brakes and 4th gen or C5 wheels guys will run a 2-2.25" spacer. With the upgrade kits often used that add the thickness of the rotor hat on top of the hub, use a 1.75" to 2.0" spacer max and you'll be fine.
Ed
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
