Low Brakes
Old Sep 28, 2007 | 06:42 PM
82 Indy Z's Avatar
Car: 1982 Indy 500 Pace Car Replica
Engine: Stroked 350 (385ci) TPIS Mini-Ram
Transmission: 6-speed
Axle/Gears: Stock w/Disks and 4.10's
Low Brakes
Hey Guys,
I tried the search feature and nothing comes up.
I have an 82 Camaro and my brakes have always been very low. I have disks on all 4's. Once the pedal travels about 3-4 inches the brakes work and apply well. When the brakes applies, the level of the pedal is lower than the throttle pedel. The brakes are their but engagement is low.
I have bled the brakes and even had firestone charge me 50 buck to bleed them and the pedel is still low. I installed a M/C off of a LS1 Camaro thinking it would solve the problem, but nothing has changed. I checked the rod/plunger that engages the M/C and it moves as soon as the pedal is depressed, so there is no play between them, and the distance from the M/C when it is installed is no more that an 1/8".
Has anyone had this issue with their camaro? Is this normal? What is the Fix? I plan to upgrade to the LS1 Brakes, but I am not sure this will resolve the low pedal issue.
Any help is appreciated,
Old Sep 29, 2007 | 12:15 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: Low Brakes
Hey Oscar..if the pedal is consistent but too low, maybe a longer pedal push rod will work?
Ed
Old Sep 30, 2007 | 01:49 AM
82 Indy Z's Avatar
Re: Low Brakes
Thanks Ed,
R u talking about the rod from the pedal to the booster or booster to M/C?
I will check it out.
jklein337
Sep 19, 2018 06:23 PM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
