best way to swap drums to disk?
Old Oct 11, 2007 | 10:44 AM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
hi i was wondering how much a rear disk swap setup would cost including calipers. i already have stainless brake lines and a new set of brembo replacement rotors for my iroc stock disc. could i use these rotors if i swap to disc rear on my firebird?
i pm'ed this to ebmiller but i ubderstand he gets alot of pms so i figured id ask on here.
thanks alot -Chris
Old Oct 11, 2007 | 08:13 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: best way to swap drums to disk?
I'm here, just busy. I wouldn't swap to the old style rear discs like your '88 and later Iroc has, it's not worth it. Go to the '89 and newer PBR style. You won't be able to use your Iroc parts you listed with the PBRs but that's the price of better braking. You can install the older discs onto your Firebird if you have all the parts but I don't stock those. If you want me to put a set together and rebuild the calipers using the recall kit (so they will work right), I can do that for you. Otherwise, a PBR disc swap onto your drum rear will run around $750-800 complete using my drum to disc backing plates.
Ed
Old Oct 12, 2007 | 02:39 PM
drex's Avatar
Car: 87 formula and 85 olds delta 88 2 d
Engine: 60's 350 holley carb and intake
Transmission: muncie 4 speed with centerforce
Axle/Gears: 3.42 99 camaro rear w/ discs
i bought a 99 camaro rear with better gears and disks for 300 bucks from a guy and had it in and driving in 4 hours... piece o' cake
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
