1LE Rotor/LS1 Caliper?
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I've done a number of searches without finding anything. I know the 1LE rotor is a little smaller diameter and thinner, but it's close enough to work. Machining the stock rotor friction area away probably works fine, but since you have to get different rotors anyway, I was curious if anyone has tried to do the LS1 calipers on the "bolt on" 1LE rotors? Opinions? Pitfalls? Just a quick street car with occasional trips to the drag strip to break parts.
TA
TA
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: 1LE Rotor/LS1 Caliper?
You can't just bolt those calipers onto the 1LE stuff, there's more to it than that. In the past I have made a C4 HD kit with a C5 caliper and it worked great, the difference in thickness is only .15" so it's not much. The problem I see is trying to fit the larger LS1 carrier between the rotor and spindle. I don't think it'll fit.
Ed
Ed
Axle/Gears: 9bolt
Thank you Ed, that was exactly the information I was looking for. I expected that it would require custom adapter brackets and hoses minimum, but clearance for the caliper carrier is something I didn't think about.
Thanks again, you're the man!!
TA
TA
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Glad to see I'm not the only person who thought of this.
Seems like a another option for people with skills.
the_hamturdler
Sep 30, 2015 12:50 PM
