drum to disc. E-brake problem.
Old Dec 13, 2007 | 05:58 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
I swapped my drum rear for a disc and cannot seem to get the cables to work. I thought I could just get the rear part of the cables for a disc setup, but it doesnt fit the front brake cable piece. Is there something I am missing?
The car is a 91 Z28, and the rear came out of a 90 IROC. I tried searching but couldnt this specific topic.
Old Dec 13, 2007 | 09:23 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: drum to disc. E-brake problem.
There are different cable designs in those years as well as a difference in the cable attachments in the trans tunnel. You need cables for a 1991 disc car, not the 1990 disc cables that you have.
Ed
Old Dec 21, 2007 | 11:53 AM
Xlr8torZ28's Avatar
Engine: LB9 & L98
guess I'll be calling NAPA. I think when I ordered the cables before, I got the ones for the rear end and not the car. I am assuming they will connect at the brakes the same way?
Old Dec 21, 2007 | 01:25 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
The calipers are the same for third gens from 89-92. They should hook up fine to the calipers. I actually have a caliper and rotor on my 90 off of a 95 Z28.
Old Dec 21, 2007 | 02:34 PM
Xlr8torZ28's Avatar
Engine: LB9 & L98
I think the rear end may have been from an '89.... its been a while, but anyways;
did some research.
For a 1991 with rear drum the NAPA part number is:
left 94262 - 65 1/4" & conduit length 46 7/8"
right 94263 - 51 3/4" & conduit length 33 1/4"
for 1989 w/ disc rear:
93858 - 56 3/4" & conduit length 40 1/2"
only lists one cable
1990 & 1991 w/ rear disc both list this one:
94264 - 56 7/8" & conduit length 40 3/4"
1991 w/ rear disc also lists this one:
94597 - 56 3/16" & conduit length 36 3/4
If I remember correctly, the one I got, the cable is fine but the conduit was short(maybe visa/versa). What I will probably do it take it back to NAPA and compare it with the others to make sure I get the right one that is the right length and with the right connectors on it.
Old Dec 24, 2007 | 01:57 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Listen to Ed. He is the brake guru.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
92projectcamaro
Dec 8, 2015 12:25 AM
HoosierinWA
Oct 7, 2015 10:15 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
