Resevoir removal
Old Dec 14, 2007 | 11:02 PM
me2's Avatar
me2
Transmission: 700r
Axle/Gears: ford 3.55
Resevoir removal
I need to remove the brake resevoir to polish the master cylinder.Is it just held in by the o rings? What is the best way to remove it? Where can I get new O ring seals?
Old Dec 17, 2007 | 08:19 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Re: Resevoir removal
The resovior just pops in and out. But the actual master cylinder is connected to the booster by 2 nuts and then of course the brake lines.
Old Dec 18, 2007 | 09:52 AM
The reservoir is held to the MC by a roll pin in between the 2 fluid funnels. Drive out the pin, the reservoir lifts out.
Leave the O-rings alone. If they're bad, then so is every other piece of the same material that's part of the same piece that's been subjected to the same conditions for the same length of time. A whole new MC isn't but like $25, it's not worth "saving" if it's used up. Kind of stupid to waste as much effort as "polishing" will be (but that's a different matter), but most especially on a limited-life wear part that might, for all you know, be at THE VERY END of its useful life anyway.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
