Brake Light
Car: 1987 Camaro
Engine: 5.7
Brake Light
I recently had my brakes done about 3 weeks ago. Everything was fine.
My brake light never came on unless the E-Brake was on then it would light up, well no when im driving my brake light will come on for a little while and go off and come back on. Im not sure what is exactly causing it, anyone have an Idea? I wasnt sure if the brake lght came on if there was brake trouble or only for the e brake.
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Brake Light
hows your fluid level??? could be low.
Car: 1987 Camaro
Engine: 5.7
Re: Brake Light
The fluid was right at the min line so I went ahead and filled it up the rest of the way, but it still comes on.
the pedal seems ok from what I remember...if the pedal was going mroe to the floor what would u think it would be??
So this light actually does come on if somethings up with the brakes other than the E-brake is on?
Re: Brake Light
yea, brake light activates if there is a prob with pressure or fluid level i believe, you may need your brakes bled. My cutlass was a PITA and i had to keep bleeding it because it was doing what you have. Just a thought. Maybe the light just likes being on
could be sumthing up with your ebrake i suppose, i know the leather boot on my truck doesn't let mine go down all the way and the light will come on and off, but then again on a maro there is no boot to make it go up at all so idk.
Car: 1987 Camaro
Engine: 5.7
Re: Brake Light
if one of the vacum lines are loose or off there could that cause it? I was working with that stuff the other day maybe ones not on good and thats causing it?
Re: Brake Light
i can't answer that one for ya...sorry!
Car: 1987 Camaro
Engine: 5.7
Re: Brake Light
Well thats not it anyways, i checked all of the vacum lines and they are attached. I took the lid of the brake fluid and went and hit the brake and a lot of air came out, maybe thats what it was, i havent got to drive it since then though because of problems with my hood shutting
Car: 1987 Camaro
Engine: 5.7
Re: Brake Light
Well im still having the same problem and the pedal is to the floor, I dont really have the money to have a shop look at it, so what do I need to do?
Car: 1987 Camaro
Engine: 5.7
Re: Brake Light
Had them looked at and they checked for leaks and said everything was fine and even bled the brakes and the light is still on, Maybe needs to be bled more?
