proportioning valve questions...
Old Feb 15, 2008 | 12:12 AM
drewdown84's Avatar
Car: 1987 Camaro IROC
Engine: V8 5.0L TPI
Axle/Gears: 10 Bolt
i wanna swap out my stocker drum setup from my 91 RS to a setup i recently picked up from a transam... its a posi 3.73 disc setup up... i was told that i could run this setup without changing my valve... im kinda iffy about this statement... anyone know from experience that i can do this... or should i be looking for a valve from another disc setup... any comments... questions... information please...
Old Feb 15, 2008 | 12:39 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: proportioning valve questions...
I heard the same thing when I put a 00' disk rear in my 91 RS. So I went with it, and it works fine. I've stood on the brakes pretty hard a couple times at ~50mph to test a panic stop and the rear didn't lock up before the fronts, however the front's didn't lock up either so it wasn't a totally conclusive test. I haven't had any problems at all though so I will say you are going to be fine.
Go for it, just be sure you test a panic stop on a safe empty road to see how the brakes behave when you need them the most.
Old Feb 15, 2008 | 02:33 AM
drewdown84's Avatar
Engine: V8 5.0L TPI
Axle/Gears: 10 Bolt
hey thanks for the testimonial... cant wait to get that rear end into my car...
Old Feb 16, 2008 | 01:17 PM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
I will be doing a similar swap. I just picked up a disc rear end with 3.23's from an 87. I needed a rear end because mine is about to grenade on me...So it was time to look for a disc rear end. I have heard from some people that they had to change their valves, but others have said there is no need as long as you use the rear valve that is on the disc axle.
Old Feb 16, 2008 | 02:31 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
I believe the prop valve is only the same between disk/drum for the 91/92 cars.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
