drums to disks
Old Feb 21, 2008 | 06:14 PM
Grizzle B's Avatar
Car: 1984 Camaro Z28
Engine: '92 LT1
Transmission: 700R-4
Axle/Gears: 3.73 factory posi. disc brakes
drums to disks
I drive a '84 Camaro. I have a drum brake rear end I have a disk brake rear end out of a '82 firebird what do I need to change?
Old Feb 21, 2008 | 08:51 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: drums to disks
Welcome to TGO. A search here is always a good thing. I'd swap in disc proportioning valve. E-brake cables.
JamesC
Old Feb 22, 2008 | 03:24 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: drums to disks
Welcome aboard..First thing I would do is at least rebuild the calipers with the recall kit, otherwise those rear discs won't do you a bit of good since they'll be frozen solid. Then it's a prop valve and cables as James stated.
Ed
Old Feb 22, 2008 | 08:54 AM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
Re: drums to disks
That rear is going to have the 10.5" iron caliper. You might want to chose the axle with the preffered gearset and convert it to the later 12" PBR disk setup. Again welcome to TGO.
6speedIROC
16
Mar 15, 2023 08:33 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
92projectcamaro
Dec 8, 2015 12:25 AM
dbrochard
Sep 25, 2015 04:56 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
