Kinked Brake line need info...
Subscribe
Apr 1, 2008 | 05:37 PM
Ok i am replacing the rear hoses with earls braided lines and for the center hose where it connects to the body it kinked at the fitting.
Carquest does not have what i need. I would like to replace the whole line from the proportioning valve all the way to that flex hose so i need to know what sizes they are.
The line i think is metric 6mm. I found a fitting at car quest that will screw into the flex hose but its for a 3/16 bubble flare. They do not have 1/4" or 6mm for that fitting...so i'm not sure what to do. The line is not in bad shape and if i can get away just flaring the line and adding a union i will...but let me know what you guys think.
The fitting that goes to the flex hose is a 12 - 1.0 thread.
What size is the fitting at the proportioning valve?
Reply 0
Apr 1, 2008 | 05:58 PM
Re: Kinked Brake line need info...
I found at my NAPA store some adapter lines in various lengths with various sized fittings on either end, including metric to SAE.
In my rear end swap, I removed the metric fitting from the chassis line and flared on an SAE nut with no problems.
Reply 0
Apr 1, 2008 | 06:23 PM
Quote: Ok i am replacing the rear hoses with earls braided lines and for the center hose where it connects to the body it kinked at the fitting.
Why? Seems to have worked well for many members to include me.
JamesC
Reply 0
Apr 1, 2008 | 07:01 PM
Quote: Why? Seems to have worked well for many members to include me.
JamesC
I think he's saying that he mangled the end of one of the hard lines while trying to loosen it. That's what tubing wrenches are for......every once in a while I sure wish I had some.
Reply 0
Apr 1, 2008 | 09:26 PM
Quote: I found at my NAPA store some adapter lines in various lengths with various sized fittings on either end, including metric to SAE.
Not sure how its going to work with a metric fitting though, i have to keep that fitting in order to use earls lines.
JamesC
Ya i kinked the fitting that goes into the hose. Not part of the earls hose itself.
Quote: I think he's saying that he mangled the end of one of the hard lines while trying to loosen it. That's what tubing wrenches are for......every once in a while I sure wish I had some.
I used PB and a flare, it just happens sometimes...
Reply 0
Apr 2, 2008 | 06:38 PM
Well, im not coming up with anything around my area, looks like im going to ask the dealer. Places around here only have 10mm fittings no 12mm "we've never seen or heard of 12mm".
I tried to tap the old part of the line stuck in the fitting out but that didnt work so i drilled it out, the line appears to be 1/4" so i drilled a 1/4" hole for that. Cut the old section out and the fitting will go over so now i guess i will just try to flare it and see if it leaks or not.
Really wish i could just order this fitting...
Reply 0
Apr 2, 2008 | 10:00 PM
Just the fittings? Look here...
http://www.fmsiinc.com/brake-line-fittings.htm
Of course you could just replace the whole line -- contact Fine Lines, Inc.
(Replying to your PM via this thread...)
Ed
Reply 0
Subscribe
