Manula Brakes
Car: 84 Berlinetta
Engine: 332 CI
Transmission: TH400
Axle/Gears: 3.08
Manula Brakes
Has anybody here switched out their power brakes for manual ones? the motor im running has such a big cam that im not going to have enough vacuum to run them anyway, and id like to clean up my engine bay some more.
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: Manula Brakes
yep many have, you can get parts for it at burkart chassis or TRZ motorsports
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Re: Manula Brakes
The manual master cylinder from a 1985-newer S10 also works great....
Kevin
Kevin
Car: 84 Berlinetta
Engine: 332 CI
Transmission: TH400
Axle/Gears: 3.08
Re: Manula Brakes
No, the master cylinder looks exactly like your factory one. You will need to fab or buy a plate to mount to the firewall. Also, you will need a pushrod to connect to the brake pedal. If yuo can find a manual brake S10 in the junkyard, everything is already there including the mounting plate and the pushrod.
Kevin
Kevin
Re: Manula Brakes
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Re: Manula Brakes
http://www.smithperformance.com/cata...der%20Firewall
I bought there kit and seems to fit well. I have not gotten my car running again yet but a friend of mine that has a 89 has the same kit and he stops just fine. His car runs low 10's.
Car: 84 Berlinetta
Engine: 332 CI
Transmission: TH400
Axle/Gears: 3.08
Re: Manula Brakes
EDIT: OK i was looking at it backwards, I see how it works now.
Car: 1987 Pontiac GTA Trans Am
Engine: Basic Stroked SBC..383
Transmission: PerformaBuilt 700R4 3000 Stall
Axle/Gears: Moser 9in. 3:70s
Re: Manula Brakes
Would I like going to manual breaks on my GTA? Is it going to be really hard to push the pedal? I just want to hear some thoughts on how well everyone likes it over power. Im having the same issue..big cam..
dbrochard
Sep 19, 2015 08:13 PM
