89 Brake line replacement
Old Apr 25, 2008 | 12:28 PM
odecca's Avatar
Car: 89 RS
Engine: 305... for now.
I was going to replace all my brake lines with stainless sometime after reinforcing the subframe. However, I now need to do it 1st.
Before I get started I wanted to ask how many lines their are to replace the whole system? I just found the leak and had to finish a project on my truck before I got started on this.
I am replacing all the hardlines in solid stainless and all the soft lines in braided stainless.
Old Apr 26, 2008 | 08:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 89 Brake line replacement
depends on what brakes you have.
there are 2 lines for the front brakes, 1 line front to back, 2 lines on the axle. 2 flex lines on the front, 1 to the t block of the axle to body, then possible 2 one the axle if you have discs.
Old Apr 29, 2008 | 12:41 AM
odecca's Avatar
Car: 89 RS
I got an 89 RS with rear drums. I was underneath it the other day and found the leak on the line going to the drivers side drum. didn't start on it though, I was taking off the rear swaybar (the end link bolts were GONE!) Brake lines are next.
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
