Camaro Hydra-Boost
Old Apr 27, 2008 | 09:29 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Camaro Hydra-Boost
I bit the bullet and bought the Hydra Boost system with the braided lines for $653.00. Which will be outfitted with the Wilwood Master Cylinder. I will also change the line to pre bent aluminum.
Here is a few pictures:
Hydra-Boost
Hydra-Boost W/ Line Kit
Wilwood Master Cylinder & Prop Valve
Old Apr 27, 2008 | 10:46 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Re: Camaro Hydra-Boost
looks like they changed it some. the ones I saw before had a billet aluminum bracket. I want it too but not enough cash right now but with the motor I am planning I won't have enough vacuum for brakes so it is the best option for me. anyway you could trace the bracket? I will pay for it. also I think if you did a write up on the install it would probably be a sticky on here since there is alot of interest in them now.
Old Apr 28, 2008 | 05:36 AM
DTL504's Avatar
The unit I got is from Performanceonline.com, since hydratechbraking.com do not sell to the public anymore once they move to their new location. The system came with direction and if my memory serve my correct they sales tech said it was a rebuilt unit from a 1988 celebrity with the mods to fit the Camaro.
Old May 14, 2008 | 06:28 PM
jstoltz's Avatar
do you have this on already? how's it working so far? I am still interested in the brackets and rod for it. but want to know if it is working oK either way.
Old May 17, 2008 | 07:39 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
This may be a dumb or already answered question in another Hydra-Boost thread but can the stock master cylinder and proportioning valve be used or did you have to switch these out?
Old May 17, 2008 | 10:42 AM
jstoltz's Avatar
the proportioning valve you are better off with an adjustable one to fine tune the system although the stock one could be used. the master needs to be machined down as far as I know but the 4th gen and c5/c6 masters will bolt right up from what I've heard though.
Old May 23, 2008 | 01:50 PM
BadZSS06's Avatar
Car: 2006 SS 2.0 Cobalt\88 383 Camaro
Engine: 383 Afr 195, 850 cfm hp
Transmission: Dynamic Racing 700r4
Axle/Gears: 9in Ford 4.11 Detroit locker
who sells this hydra boost unit? i have been looking to do this and have not found anything like this yet
Old May 23, 2008 | 02:58 PM
jstoltz's Avatar
looks like www.performanceonline.com
Old May 23, 2008 | 06:19 PM
DTL504's Avatar
Originally Posted by jstoltz
That's the place, I have not installed the unit yet because the bracket were sent out for chrome and the unit is tape for painting.
Old May 24, 2008 | 07:17 AM
BadZSS06's Avatar
nice! thanks guys my wallet just got smaller. You were able to get it with out the master or you had to get it with the master and then buy the wilwood setup?
Old May 24, 2008 | 09:19 AM
DTL504's Avatar
I bought it without the master because I already had the Wilwood. I might be going with a different Master, so If you are interested in the Wilwood I can save you a few bucks on this one. It's Brand New in the box; just took it out to take pictures. I will let it go for $215.00 + shipping.
Old May 24, 2008 | 11:58 AM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Am I missing something? You said it was $653. Yet the web site has it for $459.10?
click here
HYDRO POWER BRAKE BOOSTER KIT
Available for All vehicles. Performance Online has developed the answer to all of the power brake issues associated with high performance vehicles.
SAVE 8% Suggested Retail: $ 499.99 Our price: $ 459.10
Old May 24, 2008 | 02:21 PM
jstoltz's Avatar
459 is no lines.
Old May 24, 2008 | 07:41 PM
DTL504's Avatar
459 is no lines.
Damn jstoltz, you are all over it... Did you tap my phone line while I was placing the order?
Old May 24, 2008 | 09:18 PM
jstoltz's Avatar
someone is always listening, I thought you knew by now so no chance on the brackets? if I had the dimensions I could probably get the brackets and rods made. It would take a while anyway. also props on the vert, looks good.
Old May 24, 2008 | 09:23 PM
DTL504's Avatar
The brackets are currently out getting chrome.
Old May 24, 2008 | 10:03 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Wowee. Just an FYI, the Wilwood master cylinder has a decent chance of not working. 90% of master cylinders won't work with 3rd or 4th gens because our booster puts the master too close to the strut tower, and with almost every master cylinder ever having lines exit on the driver's side of the master, and ours exiting on the passenger.... Leaves us few choices.
4th gen master cylinder will bolt right up to the hydroboost, no machining.
Old May 24, 2008 | 10:14 PM
DTL504's Avatar
I know your teacher told you to read the whole story in grade school... I am using a Hydroboost, which could flip on either side....
Old May 24, 2008 | 10:15 PM
Axle/Gears: 3.27 BW
Your master cylinder can't run upside down too, can it?
And the wowee was gonna be an initial comment of the price of that kit. I got my master for $10, my Hydroboost Unit for $35, and the most expensive thing (which I have yet to do) is the lines.
Old May 24, 2008 | 10:39 PM
oil pan 4's Avatar
Car: 89 Firebird
On my truck the P/S pump doesn't put out enough to cut the wheel and apply the breaks at the same time like when some jack off pulls out in front of you or some one opens a car door in a parking lot.
Old May 24, 2008 | 10:41 PM
Axle/Gears: 3.27 BW
I read that that could happen if you "T" the return lines from the booster and the steering box into the same return line. Most recommend that you braze a second fitting on to your power steering pump housing so you don't create any blockages.
That, or it could actually be your pump not putting out enough. They have HO pumps on Summit.
Old May 24, 2008 | 11:32 PM
DTL504's Avatar
The Wilwood have line on both sides, so that should not be a problem. I have plenty of room on either side.
Old May 24, 2008 | 11:34 PM
Axle/Gears: 3.27 BW
Ah. Now that, I was unaware of. From every picture I've ever seen it looks like they only have ports on one side of the cylinder. That's good to know. Gives me another option that looks a little flashier than a 4th gen master.
Old May 24, 2008 | 11:41 PM
DTL504's Avatar
This Brand New Wilwood Master Clylinder is for sale if you are interested.
Here is a shot of both side to nix the myth...
Side One
Side Two
Excuse the Corona Light......Had a few tonight
Old May 25, 2008 | 12:13 AM
Axle/Gears: 3.27 BW
What's the part number on it? I wanna see if that was something I was just completely scanning over while I was browsing through summit or what.
Oh, and the hose ends they gave you, are they 90* or 45*?
Old May 25, 2008 | 08:54 AM
DTL504's Avatar
The part# Wil-8555P "P-Polished".
http://store.summitracing.com/partde...5&autoview=sku
90* bends on the hose ends.
Old May 25, 2008 | 10:15 AM
jstoltz's Avatar
so after it comes back then could you give me the dimensions? I want to try and do it in Cad (I just started messing with it 2 days ago) I want to do the bracket in billet aluminum so it would be one piece like how hydratech's bracket is. but the bracket like yours would be much cheaper but I am not sure why they have it out so far compared to the hydra tech bracket? seeing that makes me believe it doesn't matter anyway. The rod is adjustable so I guess that takes care of it. the rod I just need pics of all of the seperate pieces to it. looks like a small heim joint, 2 nuts, and an adjuster that matches the thread all on a piece of threaded rod. seems easy enough, but I have no idea how long it is supposed to be. I am thinking if I could get the brackets made depending on how much it would cost per run and to get the stuff for the rod. getting it and selling just that for around $100 that way anyone on here can get their own pump and lines.
Attached Thumbnails Camaro Hydra-Boost-2m2waol.jpg   Camaro Hydra-Boost-1stgenfcarplates.jpg   Camaro Hydra-Boost-dsc02175.jpg
Old Oct 24, 2009 | 01:48 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
so if your vaccume boost works ok this is unneeded?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
