How do you prevent air from entering MC?
Old May 10, 2008 | 05:23 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
My rear line from the prop valve to the rear spliter is coroded and looks ready to bust (already happened to me on another car).
I need to replace that line but I am afraid of removing the line and having air enter the prop valve and MC when I do this. Any tips on preventing this?
Thanks.
Old May 10, 2008 | 06:24 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: How do you prevent air from entering MC?
make sure the master never runs out of fluid. If you can, cut the line off the master, dont unscrew it, then cap it with something or tape the hell out of it to prevent/slow down the fluid loss. the run the new line, connect everything and then remove the old fitting and swap it over. The again when you bleed the new system, make sure the reservoir never runs dry and you should be golden
Old May 10, 2008 | 08:08 PM
Car: 92' RS
Engine: LO3
Should I buy a fitted pre-bent line or take the old one out and bend a replacement line myself?
Is it feasible to bend one to match?
Old May 10, 2008 | 08:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you CAN make your own, but it will look it. the biggest issue is getting the right size line and flaring it. ISO bubble flare, kind of a pain to make. Plus if your old fittings are shot, good luck finding new ones. I would just get a new prebent line, they dont cost all that much and you can get them in stainless so they never rust again
try finelines
Old May 10, 2008 | 09:00 PM
midwest's Avatar
try finelines
how do you install a prebent line with out taking everything off the shell or bending the line to fit?
iso bubble flares easier to make then inverted double flares. The iso requires one less step. You can make a flare that will work with a iso flare with a regular double flare tool. You do every thing the same, but you just dont do the last step of pushing the flare in with the 45degree cone. Is it exactly the same no, will it work leak free, yes.
Or you could buy a iso flareing tool(harbour freight) and metric line (carquest ). These days they are not that hard to find.
Carquest also sells adapter fittings.
And to answer the original post. Fill up the master as full as you can get it, and then put the cap back on and leave it. It wont drain as fast. Make sure you keep the master full. It realy doesnt matter that much, cause your going to have to do a normal full bleed on the rear brakes anyways.
Old May 10, 2008 | 09:18 PM
kcb37's Avatar
If you leave the cap on it won't let air into the MC from the top, and for the most part will hold the fluid in the lines.
Old May 10, 2008 | 10:18 PM
Car: 92' RS
Engine: LO3
try finelines
I already have an ISO bubble flare tool that I used when I replaced the same line on another car. I just had some brake line and bent it myself. It was crude but it worked as I didn't care how 'clean' it looked on that car. Not sure how I kept air out of the MC on that car. Just lucky I guess.
I have been searching and they have brake line bending tools for $30. I may go this route since you never know when you need to bend more lines.
Old May 11, 2008 | 12:50 AM
kcb37's Avatar
If you are careful and don't need to make a real tight bend you can use sockets to bend the lines around. You just have to go slow and be careful.
That is how I have been doing it for several years.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
