Rear Rotors?
Old May 13, 2008 | 09:43 AM
wayfastf150's Avatar
Rear Rotors?
I have a 88 formula ws-6 which to my understanding had drums on the back from factory even though it was a ws-6. My car has rear disks so am I wrong and did the ws-6 come with rear disk or did someone do a conversion?
Old May 13, 2008 | 10:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear Rotors?
Likely the car came equipped with discs--the IROC, for example, could be equipped either way.
JamesC
Old May 13, 2008 | 10:46 AM
Guest
Guest
Posts: n/a
Re: Rear Rotors?
The WS6 option didn't necessarily include the rear disc brakes. Some years it did, 1988 it did not... but it was a separate option available if the car had WS6.
Old May 13, 2008 | 10:49 AM
Re: Rear Rotors?
So it is possible it came out of the factory with the disks on the back.
Old May 13, 2008 | 10:51 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Rear Rotors?
yes
Old May 13, 2008 | 11:26 AM
Re: Rear Rotors?
Does anyone know what size rotor pontiac would put on the back in the factory just so I can hopefully tell if they came from the factory or not? Is there any better way of figuring out what size/type of brake it is so I can order new rotors and pads if I need to?
Old May 13, 2008 | 11:29 AM
JamesC's Avatar
Re: Rear Rotors?
Check for single-piston Delco-Moraine iron calipers with 10.5" rotors on all four-corners (non-performance package).
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
